Brand of Capacitors to fix motherboards
  • computersplus2005
    • Nov 2010
    I have stackes of bad motherboards I want to start recapping.
    I made a list of the most common specs from what I could see .
    Here is my list.
    6.3v 3300uf *
    10v 1000uf *
    6.3v 220 uf
    25v 220 uf
    16v 1200uf *
    6.3v 100uf
    6.3v 1000uf *
    6.3v 1800uf
    16v 1500uf *
    25v 100uf
    6.3v 100uf
    10v 470uf
    16v 100uf
    25v 10uf
    25v 2uf
    The ones with the * are the most common ones.
    after reading many posts it looks like I dont have all the specs(not sure if i need them)
    I want to order replacements for most all of these but cant decide on the brands.
    I will not be over clocking or doing anything high end with the recapped motherboards.
    Just got a decent Soldering station and want to see what I can get working.
    Please help.
    Thank you.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: Brand of Capacitors to fix motherboards
    Browse my inventory, I have almost every one of those values. The few that I don't have direct replacements for, I have more than adequate substitutes.
    The 1200uF 16v, use 1500uF 16v, done all the time and works fine. For the 10uF 25v, use 22uF 25v. 2uF? I've never ever seen one of those fail.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      You didn't take into account diameter and you will find that can be a big deal.
      Everyone has their own 'program' as it were.
      This is mine for mobos.
      - If it's 85C, it goes. [Doesn't matter what brand.]
      - 8mm and up and a bad brand [or any failed] then they go.
      - 6.3mm of 220uF and up are handled like 8mm and up.
      - 6.3mm of less than 220uF are handled like 4&5mm.
      - 4&5mm stay unless they are 85C [or any failed].
      That fixes the vast majority of boards.
      You also need to split up your list by grades of caps.
      A ZL or KZE or WX is usually fine in the Vcore on a P3 but not usually] on P4 and up.
      After you've done a few you will begin to get a feel for what grade should be where based on what you see there as original over and over.
      Mann-Made Global Warming.
      - Dr Seuss
      • bigbeark
        • Jan 2010
        • 661
        Many boards use those 4 & 5mm caps for onboard sound.
        Many sound cards fail because of these little caps.
        I've brought the sound back on many boards and sound cards by replacing these caps.
        I always replace these little caps. It's amazing how much *louder* your audio is after doing this. Just my 2 cents.
        If I am recapping an older board that has had a harsh life (read blade server boards) I will replace everything except polys. For socket 478, anything electrolytic near the heatsinks is replaced (except polys). For cooler running
        modern boards I follow PCBONEZ suggestions
        • Deby
          List of compatible laptop motherboards
          by Deby
          This is a list of compatible laptop motherboard information that I have been collecting for some time.
          And it's still ongoing.
          Every time I come across information that a board is compatible with another, I write it down.
          Anyone who wants to, can continue to expand the list.
          Packed in the rar, is an excel table that has additional information.
          Motherboards.rar...
          05-31-2024, 04:34 AM
        • petehall347
          100nf and 100uf precision capacitors
          by petehall347
          i am wanting to calibrate my multimeters and for this i require a 100nf and 100uf precision capacitors . trouble is i can't find them ....
          08-13-2024, 06:56 AM
        • amelbye
          degradation of solid state capacitors in motherboards?
          by amelbye
          Hi, I have a question regarding a motherboard with SS capacitors that I'm having trouble with. Every now and again it would give overclock failed at boot even when not overclocking.
          Recently more often, and the last few weeks at every single boot. It seems like the typical capacitors needing to warm up, then everything is fine.
          Weird thing is the capacitors are all solid state. Do SS capacitors degrade the same way as normal caps? Is it worth trying to recap the board?
          I have already replaced the PSU.
          The board is a gigabyte x79 ud3....
          11-06-2022, 10:35 AM
          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
          I am comparing them to a brand new one that I installed
          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
          I going to let it run for several days before I remount back on the wall next to the...
          09-05-2024, 06:48 PM
        • madscientist750
          Replacing electrolytic caps by solid caps on old motherboards
          by madscientist750
          I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
          I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
          I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
          10-19-2025, 06:10 AM
