Identifying a GPU capacitor...
  • Fingers66
    • Nov 2010
    • 6
    Due to fat fingers, I pulled a cap from an HIS Radeon 5770 GPU.
    The graphics card still works fine, no artifacts or glitches under full load using Furmark.
    I need some advice...
    1. Should I replace it at all?
    2. If I don't replace it, what kind of symptoms should I watch out for?
    3. Can anyone help me identify the specification of the capacitor?
    Graphics card as it comes before fat fingers attack...
    Pic showing the capacitor pins still in the PCB...
    Same pic, different angle...
    Pic showing underside of PCB with the cap pins coming through...
    The cap itself...
    Underside of cap...
    Your expert advice would be most appreciated.
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Re: Identifying a GPU capacitor...
    Looks like a 100uf, 16v cap. Perhaps a solid polymer one.
    • Toasty
      • Jul 2007
      • 4171
      Diameter? Height?
      6.3 x 10.5 mm:
      http://search.digikey.com/scripts/Dk...me=565-3053-ND
      8 x 11.5 mm:
      http://search.digikey.com/scripts/Dk...me=493-3716-ND
      Toast
      veritas odium parit
      • Fingers66
        • Nov 2010
        • 6
        Thanks for the feedback, I'll measure it up when I get home and post back.
        So is it a polymer aluminium cap? Any idea of manufacturer? Definately a 100uF 16v?
        The only reason I ask for confirmation is that I have seen some manufacturers shift the decimal place on the rating e.g. 10 = 100uF, 100 = 1000 uF etc.
        Sourcing one and replacing it (assuming I need to) in the UK will be straight forward. It is the identification that is tricky.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          If its working without it, it cant posibly we worse to put the wrog one on
          • Toasty
            • Jul 2007
            • 4171
            Yes
            Whoever was cheapest at the time they built the board.
            Yes
            Would be an odd value on the drain of that FET next door. If in doubt, remove another from the board and measure it.
            Toast
            veritas odium parit
            • Fingers66
              • Nov 2010
              • 6
              I've measured the cap as best I could (I can't find my micrometer).
              It is 8.5mm tall with a diameter of a touch over 6mm. I haven't been able to remove the card yet to see if there are others of the same spec on the PCB.
              When you say remove another cap and measure it, I assume you mean measure it with a multimeter to determine its' value?
              • Toasty
                • Jul 2007
                • 4171
                No. A capacitance meter. If you want to verify that the markings match the capacitance.
                Yes, some manufacturers mark them differently. Other's values are -as- printed.
                100 = 10uF
                101 = 100uF
                102 = 1000uF
                470 = 47uF
                471 = 470uF
                etc.
                I don't believe that's the case here given the size of the cap's can and positioning in the circuit.
                Toast
                veritas odium parit
                • yyonline
                  • Jul 2009
                  • 692
                  That cap is likely Lelon OCRZ series, which is a polymer capacitor:
                  I see a lot of them on HIS cards.
                  16V 100uF is 6.3 x 8 mm. 10 mOhm ESR, 4500 mA rated ripple current.
                  For a replacement, you want the same or less ESR, and the same or more ripple.
                  This may be a tricky cap to locate a replacement for. OCRZ has very good specs for its size. That said...I see through-holes for a larger size cap. If you use the holes with the larger spacing and move up to 8mm diameter, an appropriate replacement is much easier to find. One possibility:
                  I see you are in the UK. I tried the Farnell site, but didn't find anything there that would work as a replacement for OCRZ.
                  • Toasty
                    • Jul 2007
                    • 4171
                    The same one I posted in response #3 above. I also offered another smaller choice.
                    veritas odium parit
                    • Fingers66
                      • Nov 2010
                      • 6
                      The smaller one you linked has a much higher ESR and a much smaller ripple.
                      Originally posted by yyonline
                      ...<snip> For a replacement, you want the same or less ESR, and the same or more ripple.</snip>
                      Based upon what yyonline said, how important is it?
                      I am trying to source one with the right rating and the right size if possible although the larger size is an option. How confident can I be that the through-hole for a larger cap is actually for that cap and not on another circuit?
                      By the way, you people are fantastic, thanks.
                      • Toasty
                        • Jul 2007
                        • 4171
                        The second one. Since we -were- dealing with an unknown manufacturer, the first choice was more for fit. ( It's also better than what's there now.... )
                        Digikey 493-3716 - 7 mOhm & 5600mA
                        Check the lead spacing. The replacement is 3.5mm. You have another unused hole there that is for a larger diameter cap as the screen printing indicates. Either will do and just swing the cap to fit.
                        It's a better cap than the original, assuming Lelon.
                        Toast
                        Toast
                        veritas odium parit
                        • Fingers66
                          • Nov 2010
                          • 6
                          Cool, thanks, just trying to find it now in UK.
                          • yyonline
                            • Jul 2009
                            • 692
                            Well, quite important. If you choose an inadequate replacement it will fail prematurely. The exception to this if the manufacturer used an "overkill" cap there that is far better than what is actually needed.
                            I'm 99.9% certain that it's the same circuit. Manufacturers often do this as it gives them more flexibility in sourcing parts. If you want to confirm, measure the resistance between the positive lead and the unused positive through hole. If you get no resistance between them, they're on the same circuit.
                            • Prolog
                              by Prolog
                              12-01-2024, 08:27 PM
                            • MORETTIGIAN
                              by MORETTIGIAN
                              Title:
                              Description:
                              Procedure performed:
                              - Removed backplate
                              - Reapplied thermal compound
                              - Reassembled card
                              09-18-2025, 12:14 PM
                            • Ambro
                              Help identifying missing smd capacitor for HP elitebook 840 g3
                              by Ambro
                              In an unfortunate mishap while attempting to read from the bios chip, one of the smd capacitors took flight and disappeared.
                              I'm not sure how crucial this smd capacitor is, but it was a brown possibly ceramic one with no notable markings on it anywhere.
                              I've attached a picture of where it's located on the board.
                              Does anyone have an HP elitebook 840 g3 who might be able to aid me identifying this component. I'm not sure how crucial it is, but didn't want to risk it.
                              Thank you for any help you can provide....
                              09-09-2023, 06:21 PM
                            • grimacelord
                              Need Help Identifying Capacitor On Kar-Tech Versa Remote
                              by grimacelord
                              I have sort of a weird one here. This is the circuit board for a Kar-Tech VERSA remote. It's a wireless transmitter for crane and other heavy equipment.
                              One of the capacitors have blown and I need help finding a replacement. The capacitors are 11.4mm x 6.6mm in size and the only imprint on them is "200mΩF", which I am assuming means 200 microfarads. There is no other markings on them. I have tried doing some searching on digikey and mouser, but I can't seem to find anything like this on there or I am inputting the wrong search parameters....
                              09-08-2023, 09:28 AM
                            • krob80
                              PS5 Edm-010 No Power - Help identifying missing capacitor
                              by krob80
                              Hey everyone. I recently acquired a PS5 that is not turning on (no beep/power). PSU is good and there is no shorting on the 12V rail.
                              It came with a Gen3 SSD installed so I feel that things went down hill for the previous owner when it was installed. F7003 was blown but there was nothing shorting to ground. I replaced the fuse but still no power (new fuse is still good for now).
                              When connecting it to a bench power supply, it only pulls 10 mA (doesn't spike when first connected).
                              I noticed that there are a couple capacitors missing from the Vcore power regulator (pictures attached)....
                              05-15-2025, 04:24 PM
