UCC caps clarification
  • bigbeark
    • Jan 2010
    • 661
    I have motherboards with KZE KZG KZJ KZM and then the KY-series.
    What are the "bad" ones?
  • mockingbird
    • Dec 2008
    • 5484
    Re: UCC caps clarification
    KZE KZG and KZJ are all low esr caps which can be used on the VRM. KZE and KZJ are deemed to be unreliable at higher temperatures but ok in areas which there is less heat. KZE is the best of all three and if I am correct, the lowest ESR capacitor UCC produces. It is reliable as any other low esr capacitor from any other reputable brand. KY according to momaka:
    United Chemicon LXY, LXZ, KY; Panasonic FC; Nichicon PW, PM, HE; Rubycon YXG
    (i.e. these are all for the same applications).
    I have never heard of KZM.
    • retiredcaps
      • Apr 2010
      • 9271
      See
      https://www.badcaps.net/forum/showthread.php?t=2280
      --- begin sig file ---
      --- end sig file ---
      • yyonline
        • Jul 2009
        • 692
        Not quite. (Not meant as an attack, just correcting some inaccurate info.)
        KZE is low ESR. It is reliable. It is equivalent to Rubycon ZL, Sanyo WX, and Nichicon HD. KZE is suitable for VRM input on most P4/Athlon motherboards, and VRM output on P3 and older boards. Generally OK in most other places on a motherboard.
        KZM is slightly lower ESR than KZE. It is equivalent spec-wise to Rubycon ZLH. I've never seen KZM, so I can't comment on reliability.
        KZG is lower ESR than the above. It is not reliable anywhere, but especially in high-heat areas. It is equivalent spec wise to Rubycon MBZ, Sanyo WG, and Nichicon HM. Approximately equivalent to Panasonic FJ. This grade cap (KZG itself not recommended) is suitable for P4/Athlon era VRM output, and is almost always OK elsewhere on a motherboard.
        KZJ is even lower ESR than all of the above. I have seen enough failures that I wouldn't trust it. It is equivalent spec-wise to Rubycon MCZ and Nichicon HN. I believe this is the lowest ESR electrolytic cap that UCC produces. This grade cap (but not KZJ) is suitable for VRM output on just about all motherboard that don't have polymer caps there.
        • mockingbird
          • Dec 2008
          • 5484
          Interesting. Thanks for the correction. So according to what you say, UCC doesn't produce any reliable low esr electrolytic caps... Regarding ZLH vs ZL, I always thought this variant was the lead-free version.
          • yyonline
            • Jul 2009
            • 692
            KZE is quite reliable and low ESR. Just not *that* low.
            ZL is RoHS compliant as per the datasheet; I don't know if it always has been or if they changed it at some point.
            I'm seeing more and more (and more) KZG recently on new boards, as Rubycon is supposedly stopping production of MBZ. I suppose with this resurgence of KZG we'll soon figure out if UCC ever fixed whatever problem caused them to fail prematurely.
              by momaka
              03-12-2025, 03:42 PM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
            • Foetuss
              Gigabyte GA-6OXT :: caps question
              by Foetuss
              Good evening
              I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
              Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
              But I was also suprised about the bigger boys, which are 330µF 25V.
              Could it be they used 25V caps because they were cheaper / available at that time?...
              02-11-2025, 12:22 PM
