How do I tell which terminal is what on an electrolytic capacitor?
  • Funkmeiser
    • Sep 2023
    • 10
    • United States of America
    Are there any markings?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8711
    Re: How do I tell which terminal is what on an electrolytic capacitor?
    usually, yes since most are polarized and there's got to be a way to differentiate the two (or more...)
      • Jul 2011
      • 6070
      There is one exception to this rule and if they are “Bi-Polar/Non-Polar Electrolytic “ they might not have any markings which is negative side of the capacitor ( however I have only seen very few of them but they are out there )
      AC motor run / start capacitors are also not marked unless they are motor run capacitors and they are for like air conditioning compressor and condenser fan motor they are marked only for the common terminal for a dual capacitor
      • Funkmeiser
        • Sep 2023
        • 10
        Wait... so are you saying that I need to blow it up?
          • 31287
          there are actually 3 types of electrolytic.
          regular ones - they are always marked and if they are new the wires are different lengths
          bipolar ones - these always say "BP" on them and are bigger than normal.
          BIG ones with more than 2 pins on them to hold them to the board.
          these can have 5 pins, maybe more and sometimes even have several caps in the same can.
          they are common in old tv's
          you should look for datasheets for such caps
          do you have an actual cap your not sure about? post pictures
          • MORETTIGIAN
            by MORETTIGIAN
            Title:
            Description:
            Procedure performed:
            - Removed backplate
            - Reapplied thermal compound
            - Reassembled card
            09-18-2025, 12:14 PM
          • cloudff7
            Electrolytic capacitor leak in storage?
            by cloudff7
            there a risk of this aluminum electrolytic capacitor of electronic device long term storage opening and leaking acid and corroding the PCB board?
            07-22-2024, 06:27 AM
          • AleXis6
            Manufacturing Date of Electrolytic capacitor
            by AleXis6
            Guys. could you help me please to decode some codes of main capacitor's producers.
            I would like to know the manufacturing date.
            Based on the information from capacitors I have - it seems easy to decode manufacturing date for Rubycon, Nichicon.
            If I understood correctly:
            1. Nichicons marks date of production as (see the attached pictures) H2116
            I don't understand the meaning of first letter - may be it is code of factory.
            21 -year
            16 week
            I bought this capacitor recently.
            another one-
            2....
            10-11-2021, 02:20 PM
          • Prolog
            by Prolog
            12-01-2024, 08:27 PM
          • beogeek
            Need replacement advice for surface mount electrolytic capacitor
            by beogeek
            I have a faulty monitor, the surface mount electrolytic capacitor 33uF 100V needs to be replaced, now I can't seem to source them locally, so my question is can I replace it with a through-hole electrolytic capacitor of the same value? Or has someone got a better suggestion?
            Cheerio...
            03-17-2022, 01:43 PM
