Bad Caps in C02 detector/alarm
  • hyperjer
    • Dec 2005
    Ok I think things are getting out of hand with these bad caps...
    The other day while doing rutine checks on all the fire alarms in my house I noticed that the co2 alarm in my garage was malfunctioning compleately.
    I opened it up and found that the cause was several bad caps...
    how could they use such bad parts in something so critical?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Bad Caps in C02 detector/alarm
    wonderful.
    crap parts in safety gear.
    post the brand and some pics.
    and welcome to badcaps!
    • hyperjer
      • Dec 2005
      The alarm is a Maple Chase Carbon Monoxide alarm modle C0-6
      will ihave images after finals
      • japlytic
        • Oct 2005
        • 2086
        This topic shows a serious issue! Imagine if those bad capacitors were in life support equipment.
          by momaka
          03-12-2025, 03:42 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
