Important to know about capacitors on the motherboard
  • asdas09
    • May 2023
    • 19
    • Finland
    What is important to know about capacitors on the motherboard?
    If you replace a new capacitor:
    Can the size of the capacitor be larger or smaller than the original?
    What values are important to be exactly the same as the original uf, a, v, ohm?
    I mean laptop and smartphone motherboards.
  • stanwebber
    did bad capacitors kill my motherboard or prolonged exposure to faulty psu?
    by stanwebber
    i've got a pretty rare motherboard that i'm evaluating for repair. it's a biostar m7mia-raid which is the only ddr socket a motherboard ever produced, consumer or industrial, with an isa slot. its 20 years old now and finally gave up the ghost last month. i was saving a dd image of the hdd to a portable usb drive when i found it unresponsive with a black screen and a solid lit hdd led. after forcing it to power down it never posted again. the psu/cpu/case fans will spin and the onboard motherboard power led will light up, but no beeps or error codes even with the cmos reset and ram plus all expansion...
    03-10-2022, 12:35 AM
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
  • dragon3x
    by dragon3x
    power on.
    Here are some examples :
    switching supply area).
    than 6.3 V.)
    03-21-2025, 02:46 PM
  • varkatope
    Need help identifying capacitors on an MSI MS6163 ver 1. motherboard
    by varkatope
    Hey there, retro fans.
    I have an MS6163 version 1 board I'm trying to repair which was obviously used as a donor because it's missing a few parts, mostly capacitors. There are few high quality images online that would allow me to read the capacitor values (bad angle, blurry photos). I thiiiink I've figured out most of the values for the missing ones except for one in particular, number C210, which is in the bottom-left of the attached photo. Could someone with this board be so kind as to take a look at theirs and tell me the capacitance and voltage values of all the highlighted missing...
    12-15-2024, 09:48 AM
  • glovecaps
    by glovecaps
    11-25-2024, 04:23 PM
