I am fighting an audio amp that first developed a popping noise with no output, then worked fine, now does nothing but make a VERY loud hum in the 60-120hz area. I am being told that the PS filter caps are most likely the problem but all my tests come up good so far. Amp was built around 1998
These are black body capxon, 820uf, 200V. Resistance with a DMM climbs from 0 to 40m ohms, I charged them with a diode tester to 1.5V. They are holding 1.1-1.3V right now. I also used a friends cap tester and they all came in around 950uf.
I tested the bridge rectifier with a diode test and it tests fine. I am at a loss on this amp. I DO have a schematic if that would help anyone. I found one bad resistor that I repaired but that still did not fix me up. I was really hoping....
The mfg indicates the caps are a known issue but because the amp is so hard to install, I really want to know the caps are bad before replacing. I do not have ESR testing. How can I test these?
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
