parameter about the Caps
  • style007
    • Nov 2005
    • 3
    i wanna know what the parameter i must to check before i replace the cap
    i see 6.3 V AND 1500 uF
    there are some additional data that i need to know?
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: parameter about the Caps
    Other than the voltage and capacitance rating, you also want to make sure the replacements are low-ESR and 105* temp rated. for most values, you should be able to find the exact diameter with a little hunting.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • style007
      • Nov 2005
      • 3
      the diameter is matter?
      the size of the caps.
      and i need exactly the same parmeters or something around.
      10x alot.
      • Rainbow
        • Aug 2005
        • 1371
        Diameter does matter - if it's too big, it won't fit. But if there's enough space on the board, you can use larger caps, of course.
        • PeteS in CA
          • Aug 2005
          • 3578
          • USA, Unsure of Planet
          style,
          I recommend that you figure out what company manufactured the part and what series it is. Then do a Google or Yahoo search for the company's website and find the series in the company's online catalog. If you have difficulty figuring out what company made it, post here what you find on the label - name, description of the company's logo - and someone here is sure to recognize it. Once you have the webpage for the series, find out what the case size, ESR, and ripple current rating is for that part - capacitance, voltage, and diameter (use a ruler - commonly used diameters are 8mm, 10mm, and 12.5mm).
          PeteS in CA
          • PeteS in CA
            • Aug 2005
            • 3578
            (Part 2)
            Then find a similar part from a good manufacturer (there is a thread in the FAQ forum that provides links to good manufacturers' online catalogs). The favored brands here are Rubycon, Panasonic, United Chemicon (Nippon Chemicon), and Nichicon (except for the "HM" and "HN" series, due to a process problem in 2004). Try to match the case size, get equal or lower ESR, and get equal or higher ripple current rating. Since caps with OK ratings from a good manufacturer will be better than caps with "excellent" ratings from a poor quality manufacturer, choosing a low impedance part that fits from a good manufacturer should suffice.
            PeteS in CA
            • PeteS in CA
              • Aug 2005
              • 3578
              (Part 3)
              Partial list of good brands and series:
              Rubycon - ZL, YXH, and YXG (other posters may recommend other good series that I can't remember)
              Panasonic - FM and FC
              United Chemicon - KZE, LXZ, LXY, and LXV
              Nichicon - HE and PW
              Sorry for breaking this up in three parts, but for some reason it was the only way I could get this posted.
              PeteS in CA
              • style007
                • Nov 2005
                • 3
                ohh thank man
                To measure the diameter i can use king of ruler.
                i will try to find the model the u mention
                but its difficult. i fint in IL store the folowing company:
                nippon
                LELON
                SAMWHA
                CHANG
                MALLORY
                u can plz rank them 1-best 5 bad.
                thank u.
                • linuxguru
                  • Apr 2005
                  • 1564
                  1 - nippon
                  2 - mallory
                  3 - samwha
                  4 - lelon
                  (unknown) chang
                  • PeteS in CA
                    • Aug 2005
                    • 3578
                    Quality-wise, the gap between Nippon Chemicon and Lelon is very large. I had a part from a current Lelon series and a part from a recently retired United Chemicon (a division of Nippon Chemicon) series (KMF) among a test group. The older technology UCC part fared far, far better under high ripple current. I suspect Samwha isn't much better. I don't know whether Mallory is manufacturing their own parts or re-branding.
                    PeteS in CA
                    • Rainbow
                      • Aug 2005
                      • 1371
                      I'd say Nippon is good and the rest is crap.
                      • Chris1992
                        • Apr 2005
                        • 561
                        IIRC Mallory is a division of Cornell Dubilier, how are CDE's products?
                        The great capacitor showdown!
                          by momaka
                          03-12-2025, 03:42 PM
                        • eryjus
                          by eryjus
                          05-10-2023, 11:21 AM
                        • Paxman_Swede
                          by Paxman_Swede
                          Hello!
                          01-14-2025, 09:51 AM
                        • captain150
                          by captain150
                          03-16-2025, 07:34 PM
                        • Foetuss
                          Gigabyte GA-6OXT :: caps question
                          by Foetuss
                          Good evening
                          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                          But I was also suprised about the bigger boys, which are 330µF 25V.
                          Could it be they used 25V caps because they were cheaper / available at that time?...
                          02-11-2025, 12:22 PM
