Nichicon HZ or Rubycon MCZ?
Given the choice, which is better?
by sam_sam_samHere is the page of capacitors that I can choose from what is a good choice for a FSP 400-60GLC
https://www.digikey.com/en/products/...Xmc1YPJ6BlESoA
I try to use a 565-1664-ND which is a 10mm in diameter unfortunately it will not fit because there are two of them the same size and value and there is no room and they go to two different circuits not in parallel...-
by DXseekerMOHello, I'm working on an old Dell XPS410 with burst capacitors. I'm trying to source either an equivalent replacement, or a replacement that will work. It's been suggested to me to use Poly caps as a replacement, but I have no idea what to order or what will work.
If anyone has a link to where I can buy what I need that would be even better.
These are the caps that have burst:
Board location: C8BV, C26BV, C43BV
Brand: United Chemi Con
Series: KZG
Size: 10mm dia X 25mm height
Impedance: (ohms max/20c, 100kHz) .012
Ripple: 2800...-
by cloppy007I've found out that the all the Nichicon HM(M) caps on this board are faulty and need replacement. However, I didn't plan in advance and I don't have good replacement caps.
The original values are 2200uF, 6.3V, 5mm pitch. According to the datasheet, the rated impedance should be around 13-18 uOhms.
There are 8 of them, 3 to the left of the CPU socket and 5 on the bottom, very close to the northbridge. They are all connected, according to my multimeter.
I think I recall hearing that I don't have to use the same capacitance for in series...08-21-2023, 03:18 PM -
by blub0815Hi,
is the replacement possible? There is a difference of factor 2 between the ESR/Impedance.
The caps are located on a motherboard.
KZG:
https://www.digikey.at/htmldatasheet...zg-series.html
ZLJ:
https://cdn.badcaps-static.com/pdfs/...a472c7fe84.pdf
BR-
by bjs59What we have here today is an Intel DG33FB motherboard, circa 2007... I need to replace some of the caps on this board... From what I have found, one of these caps was sort of well known here back in the day as they were used in XBoxes and XBox 360s as well....They are the Rubycon MFZ series, in particular the 6.3 v 3300uf 10mm X 20mm... I have found a seller on Amazon, The Capacitor Store, that has them listed but I have a hard time believing these are genuine pieces... The original recommendation was to replace any bad ones with Nichicon HZ series since the Rubycon MFZ's were a custom product,...
- Loading...
