gx620 please advise.
  • marcink99
    • Oct 2010
    I have a gx620 with amber light sometimes it will boot or schow green with diagnostics lights 3 and 4. I checked all the parts so I know that motherboard is to blame as I have couple gx620 so swaping parts was not a problem. I do not see any bad caps but mayble you will see something that I dont. Please advise
  • Mark D
    Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
    by Mark D
    The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
    10-29-2024, 03:15 PM
  • 2elw
    SVOD4 PCB pictures + parts
    by 2elw
    Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
    STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
    GW1N-UV9UG169C6/I5 FPGA - Its a...
    07-04-2025, 12:23 PM
  • SurrealMustard
    What parts can be salvaged from a plasma with a damaged display panel?
    by SurrealMustard
    I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
    03-09-2025, 08:29 PM
  • DynaxSC
    Asus Rog Strix B360-I Gaming - Parts Identification
    by DynaxSC
    I have an Asus Rog Strix B360-I Gaming with missing parts. I know there is a resistor missing for sure, but nearby it seems there might have been also a transistor or mosfet. Below the picture of the area on the board with the missing parts. The interesting area is inside the rectangle.
    I'd appeciate if somebody could make a detailled picture of this area from a working board and post it here. Getting the parts values would also be helpful. The revision of the board is 1.02 .
    Thanks in advance...
    08-23-2023, 07:56 AM
  • Mita99
    Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
    by Mita99
    Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
    Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
    Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
    04-27-2025, 07:20 PM
