Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
Aluminum SMD capacitor replacement
  • LeBeauLuc
    • May 2021
    • 5
    Hi badcapers,
    I am quite puzzle, I am trying to figure out what will be the best replacement for my SMD caps. Knowing that I have no info on the brand and the specifity of the caps, I am quite unsure about what to use, should I go back to SMD aluminum caps or radial caps? Any recommendation for a SMD type to use?
    I have included a picture with the current ESR on each cap, you can see that some are pretty dangereously out of specs.
  • spiros.p
    • Dec 2020
    • 89
    • Greece
    Re: Aluminum SMD capacitor replacement
    i have successfully replace a lot of them in different boards with electrolytics panasonic FR and nichicon CY- CS
