Tiny Choyos & a couple GSCs on a Gigabyte GA-7N400 Pro
  • StevieC
    Talkative Loon
    • Sep 2008
    • 19
    The Choyos are 100uF at 10V, and measures 5 mm in diameter by 8 mm tall.
    the GSC is either 2.2 uF or 22 uF at either 2.5 V or 25 V and measures 5 mm in diameter by 8 mm tall. a 2nd GSC is marked as 100 uF at 16V or 1.6V and measures 5 mm across by 11 mm tall Neither the Choyos nor the GSCs have any vents and there's one each of the 2 GSC sizes, and 11 of the Choyos (all the Choyos are identical as far as I can tell)
    Are they small enough to leave well-enough alone or should I replace them?
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Tiny Choyos & a couple GSCs on a Gigabyte GA-7N400 Pro
    MOST of the time you can leave those alone.
    They do fail but not very often.
    If the larger caps are good and board is acting weird and you can't find another reason then try replacing those too.
    Mann-Made Global Warming.
    - Dr Seuss
    • StevieC
      Talkative Loon
      • Sep 2008
      • 19
      ok. I've identified the relevant caps. I'm doing the whole thing as a preventive measure, as the larger caps are mostly Nichicon HM(M)s which are known for being iffy so I'm going to replace them. One cap is so close to the CPU socket that the CPU heatsink fouls it. Is it safe to install the replacement with more length on the leads to orient it to lie parallel to the mobo?
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        HM with date codes 2001-2004 should be considered bad.
        2005 and up are okay unless heat kills them. [Like in Dell/HP toaster ovens.]
        Same-same w/Nichicon HN.
        - Dr Seuss
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          StevieC; You could poly mod it around the CPU socket if you are having problem with the capacitors height
          Laying it down works too, but it is not very good because it increases the ESR... (short leads are important...)
          • StevieC
            Talkative Loon
            • Sep 2008
            • 19
            Alas, there are no polymer caps of the appropriate voltage and capacitance for that particular position so the only option I'm left with is longer leads, or angling it outwards slightly to minimize the increase in lead length.
            • DynaxSC
              GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
              by DynaxSC
              I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
              General test conditions:
              - Tested with Core i5 6500 and Core I7 6700K - no difference
              - Default BIOS settings, but tried also altering several memory setting - does not change anything
              What is wrong:
              With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
              When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
              03-21-2025, 06:23 PM
            • chth96
              Is it possible bridging tiny broken trace
              by chth96
              When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
              cutting tiny trace.
              This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
              Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
              But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
              12-03-2022, 11:32 PM
              LENOVO ThinkCentre M72e Tiny ThinkCentre M G465 Specification for Upgrade or Repair
              This specification for the LENOVO ThinkCentre M72e Tiny can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M72e Tiny boardview and ThinkCentre M72e Tiny schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-12-2024, 03:36 PM
              LENOVO ThinkCentre M72e Tiny ThinkCentre M G460 Specification for Upgrade or Repair
