Quanta DA0P5HMB8F1 rev. F
  • supermattch
    • Sep 2025
    • 6
    • usa
    I need the schematic and boardview for the Quanta DA0P5HMB8F1 revision F. The laptop is a HP 15dy-2021nr. I keep finding similar boardviews but not this particular one. The components are in different places than those similar ones. Thank you.
  • lpraderi
    Need help with HP15-fxxxxx Quanta U99/U92 LVDS <> eDP conversion.
    by lpraderi
    Hello , for some time I was studying Quanta U9x/8x schematics and the option to use both type of screen (LVDS 40 pin / eDP 30 pin).
    In some cases to use LVDS screen PCB use converter IC RTD2132/6
    Now I found an HP 15 F series U99 mainboard with RTD chip not populated and LVDS 40 pin lcd touch screen
    at the same time I have another HP 15 N series with Quanta U92 mainboard and RTD2136 with eDP 30 pin lcd screen (no touch).
    Maybe someone more experienced in the subject can clarify if is posible to change type of screen used with some resistors / bios options change.
    11-25-2023, 09:31 AM
  • supermattch
    HP 15dy-2021nr wont power on mystery volts
    by supermattch
    Hi everyone.
    I am diagnosing my personal laptop, because it wont power on and no leds light up.
    At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
    Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
    09-23-2025, 12:13 PM
  • Francisco.s
    Quanta N76 power-on issue.
    by Francisco.s
    Hello, I'm trying to repair an HP 27 Quanta N76 (DA0N76MB6E0 Rev E).
    I only get 3.3V, 5V, and 1.05V; no other voltages.
    I tried the BIOS and changed the KBC. The KBC self-programmed upon power-up after changing it.
    The VR-On is missing for NCP81220, but 1.2V is also missing for DDR4, so 1P2V_PWRGD is low. SUSON or DDR_VTT_EN are not present on the DDR4 voltage regulator (RT8231BGQW). It seems the KBC isn't triggering these signals.
    I'm using the Quanta N91 schematic, but there are too many changes that make it nearly impossible to measure signal...
    07-14-2025, 02:20 PM
  • ruletero
    DA0P5HMB8F1 Turn on, no video, consumes only 22 mA
    by ruletero
    Hi everyone
    Model: DA0P5HMB8F1, Rev F
    Please your help with this mobo, DA0P5HMB8F1, it turns on but no video appear and consumes only 22 mA, no suson signal, EC and PCH bios updated, no success.
    It responds to power button and try to bring up without success and next it restart with the same cycle, it just restarts all the time, no schematic available, I'm using OP5D schematic, below my measurements on KBC
    Any idea what I have to review?
    thank you...
    01-14-2025, 06:27 PM
  • pleomax1110
    Quanta DA0R05MB8D2 Rev. D (Quanta R05 / Dell 14z-N411z) schematics needed
    by pleomax1110
    Hello, everyone!
    I need schematics of this board:
    Model: Dell Inspiron 14z-N411z
    Board No: DA0R05MB8D2
    REV: D
    Quanta project: R05
    I have already seen the file ''quanta R02_UMA.pdf'' in this thread:
    https://www.badcaps.net/forum/showth...dell+14z-n411z
    but it is differ from R05_UMA and it can't help me in my case.
    The main problem of the laptop is as follows:
    LED backlight is absent in the screen and appropriate 36's contact of the LVDS 40pin 1ch connector is shorted...
    10-21-2022, 01:56 PM
