Alguem da comunidade poderia me ajudar com o Board View da GTX 550 TI de 1GB
Board View GTX 550 TI 1Gb
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by RezendesHello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...-
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by Garret Matt.Hello,
I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
Thank you in advance for any assistance you can render.
Inductor In question. Buzzes like...-
06-20-2025, 01:21 PM -
- Loading...
