I need the schematic of "W86_MB Ver: C"
  • Francisco Legal
    • Jan 2025
    • Argentina
    It has charging problems, when I plug it in and it is on it gives an error, it charges and stops charging intermittently
  • coasterghost
    Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
    by coasterghost
    For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
    Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
    Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
    System Hardware:
    Processor: AMD Ryzen 7 PRO 5850U
    Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
    09-08-2025, 10:46 PM
  • Julian Bailey
    HP ProBook 445 G8 Battery not charging
    by Julian Bailey
    Hi all
    We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
    The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
    I have gone around the board with a MM and cant find anything
    Windows shows the battery fine,...
    10-11-2024, 10:34 AM
  • SluggerB
    Help with trying to fix phone that is not charging (Pics inside)
    by SluggerB
    I have two TCL A30 phones.
    Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
    New Phone: Works fine, bought as a donor board to try and repair Old Phone
    My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
    08-12-2024, 08:11 AM
  • kingskie
    HP X360 Convertible 14-dh1055TX no charging - boardview and schematic
    by kingskie
    hello everyone,
    i have a problem with HP X360 Convertible 14-dh1055TX that cannot charging.
    does anyone have boardview and schematic for this laptop?
    i measured some points on the battery pin charging on the motherboard as you can see in the attachment.
    any suggestion would be appreciated.
    thanks...
    05-15-2023, 12:48 AM
  • ahmarzo
    Hp 15 gaming laptop charging problem
    by ahmarzo
    Have laptop motherboard la-f841p with charging problem in power on mode.the laptop charges in off condition but when powered on it goes on battery mode and stops charging and gate voltages of the first and second MOSFET goes to 0v.
    Here is the link to the boardview plz help https://www.badcaps.net/filedata/fetch?id=2132131 as I can't find the schematic anywhere.
    08-26-2024, 10:07 AM
