Seeking Datasheet for 53A3P IC -- Switching IC Used in Appliances
  • Callixus
    • Aug 2025
    • 17
    • US
    That image was not very helpful since it doesn't say what 1, 2 and 3 are . . .
    • Callixus
      • Aug 2025
      • 17
      • US
      Not a very helpful image, above, since it doesn't say what pins 1, 2 and 3 are . . . See attached.
      • R_J
        • 9583
        Click image for larger version  Name:	enlarged J1.jpg Views:	3 Size:	217.9 KB ID:	3729875
        I used the same size font as the rest of the components; I will enlarge that portion of the board for you to see the numbers.
        Your picture does not show the numbers on Q2, but configured as it is to drive the relay, the base would need to be driven by U2
        If it was reversed, the base would be connected to ground.
        If the transistor lead was broken, that would explain why it was not working.
        • Callixus
          • Aug 2025
          • 17
          • US
          Ah . . . OK! . . . I was just so focused on the numbers on the 53A3P IC . . .
          Well, we'll see about the transistor. IF that one is the one I did not pull, and if it was already broken (after all, I was amazed this morning when I thought I had broken it just tilting it a little, because it was literally going to be the most brittle thing ever seen . . .)
          I should have one on Tuesday.
          Thanks again!
            by sam_sam_sam
            03-31-2024, 02:12 PM
            by sam_sam_sam
            07-01-2024, 06:34 AM
            by sam_sam_sam
            After all of...
            07-13-2024, 08:14 PM
            DVR camera recorder switching power supply capacitor failure really
            by sam_sam_sam
            These cheap non brand capacitors at it again
            Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
            Well at least I have the cameras back on line I to try the...
            01-22-2022, 06:28 PM
          • michel74
            How does this switching PS work ?
            by michel74
            Yes ! How does this switching PS works ? :-)
            I understand (not in deep, of course) the switching PS principle; typically, I'd expect to get a VCC just to "feed up" the STR or the Switching regulator, but I cannot figure how this VCC is "created" (on a TV switching PSU, I often see some cascaded resistors, but here, I believe that one of the transformer input should make the permanent VCC, but I cannot figure where )
            Thanks for your help. I already wrote some explanation of what I was having and did some measurements here ...
            11-02-2023, 12:35 PM
