FDV301N, FDV301N-F169 Datasheet
    This FDV301N, FDV301N-F169 N−Channel logic level enhancement mode field effect transistor is produced using onsemi's proprietary, high cell density, DMOS technology. This very high density process is especially tailored to minimize on−state resistance. This device has been designed especially for low voltage applications as a replacement for digital transistors. Since bias resistors are not required, this one N−channel FET can replace several different digital transistors, with different bias resistor values.
    FDV301N, FDV301N-F169 Features
    • 25 V, 0.22 A Continuous, 0.5 A Peak
    - RDS(on) = 5 @ VGS = 2.7 V
    - RDS(on) = 4 @ VGS = 4.5 V
    • Very Low Level Gate Drive Requirements Allowing Direct Operation in 3 V Circuits. VGS(th) < 1.06 V
    • Gate−Source Zener for ESD Ruggedness. > 6 kV Human Body Model
    • Replace Multiple NPN Digital Transistors with One DMOS FET
    • This Device is Pb−Free and Halide Free
  • Francesc V.
    Onkyo A8200 - Not the right voltages in some transistors
    by Francesc V.
    Hi:
    I am trying to repair this amplifier that I've bought as faulty. I've found some transistors damaged, the ones where I am drawing a red circle.
    With the final transistors not yet installed (the expensive ones), I've started to measure some voltages:
    Where I am supposed to have 1.12V (base Q524/Q523) I am reading -42V..................both channels don't seem ok.
    Where I am supposed to have -1.12V (base Q526/Q525) I am reading -44V..................both channels don't seem ok.
    I removed and tested Q514,Q516 & Q513,Q515 but the analyzer...
    04-19-2025, 07:17 AM
  • redbaron1007
    Sundown SFB-8000D What are these transistors?
    by redbaron1007
    I had a Sundown SFB-8000D amp come into the shop yesterday that wasn't giving any output. The guy who brought it in said he bought it off some crack head on Facebook marketplace for a good price, but bought it knowing it was broken. Apparently the original owner was cutting out the transistors to the right of the ones pictured whenever one would blow and take the output out. Best I can figure he also cut the legs on the S5 and S6 ic's as well and soldered them back together.
    My problem is Sundown decided in the factory to remove the original markings on the IC's and now I can't figure...
    11-12-2023, 07:30 PM
  • Bob Wong
    MSI Crosshair 15 A11UEK. Need help with Transistors!!!
    by Bob Wong
    Welcome badcaps, repairing a Crosshair 15, in need of transistor specifics. Received a broken laptop that's was perfect for repair, threw away the looser transistors in a haste... Should and could have salvaged them.
    In any case, I will be posting all my discoveries to this forum as a thanks in advance. Thanks in advance lol.
    P.S. If anyone is familiar with such things, as in, If anyone knows that MSI uses one or one of a few types of transistors when marked with a number please let me know how I can find more specifics before I start throwing hail marys.
    03-15-2025, 02:02 PM
  • wolf1976
    is there any univarsal wifi motherboard that supports and digital tvs ?
    by wolf1976
    hi i want to convert my simple digital tv because the motherboard is dead to wifi motherboard but with the ability has and tuner for digital channels DVB-T compatible in europe
    is there ?
    do you have to suggest me one ?
    thanks on advance...
    01-05-2025, 04:29 PM
  • hyva_ana
    Marantz PM-66SE Burns Transistors
    by hyva_ana
    While ago I replaced those big filter caps to that amplifier. After that started to happen. I connected the amplifier normally to the mains and almost immediately several transistors burned out. I really didn't do anything else (at least on purpose) than replaced those big caps C801 and C802.
    After that I replaced those burned transistors (I can't remember exactly what they were) and measured all the others, and now everything should be ok. But, when I power up that amplifier part with two bench power supplies connected in series there is obviously still something...
    02-11-2023, 06:34 AM
