Acer AL2416 AL2416W 24" 1920x1280 LCD Monitor
  • severach
    • Aug 2007
    • 1055
    I got 4 of these in with no back light. The TDK TBD292LF EA02B292T PK07V00330I A668.TBD292LF.TDK XinE 2 inverter has quantity 10 of 100uf 35v 105*C (NK CON) WK CON EVL series capacitors. EVIL they are too. The first two monitors I fixed by replacing bulged caps C34, C35, C36, and C38 which get burned up by Q6 and Q4. I left the remaining non bulged caps. All I could find at the time was some 100uf 25v 85*C 2000 hour Nichicon VR caps. These ended up working fine for more than a year and were not damaged when removed. The other two monitors had the same 4 caps bad but they didn't work after fixing. MOSFETs Q6 and Q4 near the bad caps were shorted so I tried to swap in the NICO P2804BDG and P5504EDG from Q3 and Q5 to get one board working but it didn't. I didn't notice all the fuses on this inverter and I didn't have any good tools to remove the small stuff so I couldn't get any farther.
    Nice detective work on the oddball MOSFETs at Need help finding replacement transistors and more possible replacement items for when the MOSFETs go at Electronics Forum: Acer AL2416W value of F2, then replace the Q4, Q6
    Lately the AL2416 I kept starts dim and brightens within a few minutes. I thought this might normal CCFL operation but I decided to open it anyways to see how the substandard temperature caps are holding against the heat because spare boards are rare on eBay and letting the caps go bad for too long results in dead hard to find MOSFETs and who knows what else. The Nichicon caps were fine but now I have more caps and better equipment so I replaced them with some lower ESR 100uf 25v 85*C 2000 hour Chemicon SMG caps and greatly improved the soldering quality.
    The power supply is equipped entirely with Rubycon YXG caps and the big semiconductors all have heat sinks. FSP100-4F01, FSP100-4F02, FSP130-4F01 look like good power supplies that won't see many capacitor failures. All caps tested great.
    The AA668 VL-2401 REV:1C video board caps Lelon 220uf 16v and 22uf 16v tested fine. A few of the Chemicon 100uf 16v 105*C KMG caps tested a bit high so I replaced C159, C135, and C154.
    So I put it all together and it flickers. Fortunately I notice that the flickering is affected by how I move the screen. I pull it back apart and the inverter cable is loose on both ends. My fault of course, but getting these connectors to seat is harder than it looks.
    Yet another year later I hear a pop and see some steam out of the monitor. Even with one magic smoke released it kept on going. As a consumer I'd ignore this and forget to mention it to the service tech when the monitor finally goes. Knowing that the MOSFETs are at risk I cut power immediately.
    Now the room smells like stale peanuts. Open it back up and the next 4 are going C1, C2, C3, and C39. The sleeves seem heat discolored compared to the remaining two C29 and C4. One has popped, one has bulged out the bottom, and the other two are as fine as they can be near the end of their life. It's a big monitor with a lot of lights that runs pretty hot and the 85*C SMG and VR caps are still going good and that's all I have so I put 4 more in and the monitor is back in operation.
    It seems odd to me that the left and right side of the TDK inverter are probably the same circuit and the layout is different.
    sig files are for morons
  • Lagunapete
    • Oct 2010
    • 8
    Re: Acer AL2416 AL2416W 24" 1920x1280 LCD Monitor
    Excellent tech work. I have replaced the four caps on the upper half of the inverter board previously and my customer said she was swapping a computer and when she plugged in the monitor there was no screen image.
    Checking on this, I noticed that the problem is not the backlighting which is working fine. This time there is a problem on the video board. No startup logo or any imaging at all.
    C159, C135, and C154 as you mention above checked out OK as well as the remaining caps.
    I'm beginning to think that it may be the ribbon cable. If only the designer spent another day or two on this model, I believe it may have been more reliable (aside from the caps they had gotten from their vendor).
    One oddity I noticed is that my revision omits the entire connector in the corner of the board next to the ribbon cable.
    RE: AA668 VL-2401 REV:2A
    • dt2rz
      • Oct 2010
      • 30
      Hi. I also have the same monitor, one day after trying to connect my ps3 to the monitor via hdmi - dvi connector cable it suddenly stop working. Shows Acer logo then monitor went to standby (front panel light turned amber). The same problem when i tried connecting the monitor to my working pc. One thing i noticed was the hdmi - dvi cable i used is no longer working (test it with another monitor and pc). So i opened the monitor but didn't see any bad/bulging/leaking/burnt caps on all the boards. I'm suspecting power supply problem.?? How can i test the power supply outputs safely?
      • retiredcaps
        • Apr 2010
        • 9271
        Quick clarification. Right at this moment, with a known good cable, known good source, does the Acer logo still show up on power up?
        To test the power supply, you will need a multimeter. Funny, we just talked about this 15 minutes ago here ...
        https://www.badcaps.net/forum/showthread.php?t=11726
        However, before you do that, just clarify the logo question above.
        --- begin sig file ---
        --- end sig file ---
        • dt2rz
          • Oct 2010
          • 30
          Thanks for the quick reply. "yes" Acer logo still shows for about 3-5 seconds and then screen turns black and the front panel light of the monitor went from green to amber. I dont have a multimeter right now, maybe i will buy tomorrow.
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            Whoever said the fsp power supply was good-well a few are but fsp is turning into crap like raidmax and powmax. Now of course i know nothing about their lcd psu offerings hut im expecting the same crap...
            • retiredcaps
              • Apr 2010
              • 9271
              Okay, another couple of questions.
              1) If you hookup a known good video cable and a know good source, do you see the display on the LCD if you shine a flashlight on it?
              2) If the image does show up, does it "flash" briefly and then go off?
              • dt2rz
                • Oct 2010
                • 30
                -Yes, i can still see the Acer logo upon shinning the flashlight.
                -Yes, logo flashes briefly and then says 'no signal' and then turns off (light on front panel turn amber)
                • jetadm123
                  • 2169
                  From the looks of post #1, now would be a good time to post some photos of the entire power supply (front and back with the steel cover off) and inverter (front and back). See links below:
                  https://www.badcaps.net/forum/showthread.php?p=118105
                  https://www.badcaps.net/forum/showthread.php?t=1868
                  And welcome to the forum!
                  • dt2rz
                    • Oct 2010
                    • 30
                    OK, I will take some pics. Thanks.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      One more question right now.
                      If you hookup a computer (that is what I meant by a source in the previous posts), can you see the display briefly and with the flashlight?
                      This last answer will tell us which direction to troubleshoot.
                      • dt2rz
                        • Oct 2010
                        • 30
                        Oh i see. Hook up to the computer that i'm using right now and shine my flashlight to the screen but no display can be seen. After showing 'acer' logo and then 'no signal' the screen is just black (its like on standby or turned off)
                        Here are some pics: I noticed something abnormal on the power supply which i circled red..
                        • mathog
                          • Mar 2010
                          • 2655
                          Take the metal plate off the power supply and show us what is under it. The covered section is where one often finds failed capacitors. (Not on this board in particular, I don't know anything about this board in particular, but it is the part of typical power supply boards where the 12V and 5V are regulated.)
                          Edit: It is even marked for you, see it says "secondary" just next to that plate.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            I'm not sure what that is on the transformer. The fact that you are getting a power LED and a "no signal/logo" suggest that most of the power section is working fine.
                            Is there a way to take off that shield (with the serial number and Rohs sticker) so we can get a peek underneath?
                            • bonney
                              • Oct 2008
                              • 74
                              Acer AL2416W
                              Inverter TDK P/N TBD292LF
                              10 capacitors 100uf 35v miniature
                              Fuse F2 marking M
                              Q4 faulty P2804BDG
                              Q6 can go faulty P5504EDG
                              Q3 faulty P2804BDG
                              Q5 can go faulty P5504EDG
                              • bonney
                                • Oct 2008
                                • 74
                                If Q5 and Q6 are weak they give you half brightness on the left side same if you dont use P5504EDG P2804BDG
                                • jetadm123
                                  • 2169
                                  Try removing the metal cover plate by reomoving the two screws on top. Also, "feel" along the bar code label for a "hidden" screw. If this doesn't release the plate, then look underneath the power board for screws.
                                  Again, we need to see what you're seeing, which means we need to see photos of the entire boards top and bottom.
                                  • mathog
                                    • Mar 2010
                                    • 2655
                                    That's the first power supply board I have seen with a shield plate like that. More typically the power supply/inverter/video card are al mounted on the back of the LCD panel and a single box-like shield bolts down over all of them. I wonder if they didn't put this plate on because of interference within the box between the power supply and the video card? In any case, that shield is going to seriously restrict airflow through the secondary part of the power supply, which will raise temps, which would tend to make the electrolytics in there fail (even) faster.
                                    • dt2rz
                                      • Oct 2010
                                      • 30
                                      Here are back side pics of the boards and power board without the metal plate:
                                      Again, here's the situation:
                                      1) Connected monitor to known working computer
                                      2) Turn on monitor
                                      3) Power LED on front panel of monitor is Green
                                      4) 'ACER' logo is displayed on the screen, then says 'NO SIGNAL'
                                      5) Power LED on front panel of monitor turned Amber/Orange, and the screen goes black
                                      • jetadm123
                                        • 2169
                                        It's hard to tell, but on the fourth photo (inverter) of your original set, it looks like the second cap above transformer T103 is domed. Also, the cap above to the left of IC2 might also be domed.
                                        • black6host
                                          Replacement caps for Samson Resolv studio monitor 65A Amp board.
                                          by black6host
                                          Good day!
                                          I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                                          I'm going to replace the caps and I'll be the first...
                                          02-06-2024, 08:22 PM
                                          by momaka
                                          03-15-2023, 10:17 PM
                                          Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
                                          by momaka
                                          I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
                                          For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
                                          https://www.badcaps.net/filedata/fetch?id=3591771
                                          https://www.badcaps.net/filedata/fetch?id=3591772
                                          It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
                                          https://www.badcaps.net/filedata/fetch?id=359177...
                                          03-12-2025, 03:42 PM
                                        • keepread
                                          Dell monitor PSU vs Dell laptop PSU
                                          by keepread
                                          Hi there!
                                          Someone gave me their old monitor, it's Dell S2715ht.
                                          The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                          Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                          10-30-2025, 04:45 PM
                                          Westinghouse L2210NW LCD monitor - bad caps repair
                                          by momaka
                                          Here's another LCD monitor repair: Westinghouse L2210NW.
                                          Quick specs: 22” CCFL backlit LCD, 1680x1050 max resolution (16:10 aspect ratio)
                                          I got it with a bunch of desktops PCs from a repair shop that was trying to free up space a few years ago. It seemed like a cheap monitor, so I didn't really care that much at first when I picked it up (and indeed it is, picture-wise.) But hey, free is free, so I can't complain. Moreover, it looked clean and the screen didn't have any significant scratches or blemishes.
                                          Pictures of the monitor outside/case after a brief...
                                          01-11-2021, 01:14 AM
