Hi guys tried doing a search of this topic before making this post, not sure if the question has been asked before.
I'm aware checking for proper voltage can be crucial when repairing LCD's just not totally clear on the proper way to do it.
If you have the LCD disassembled.. where do you measure for the 12volt rail etc? What is the procedure? Example: when checking voltages to the logic board.. do you keep the connector between the power/inverter board on or do you do remove it?
I read about putting the negative lead to a ground screw on the chassis, that much I understand.. just not sure where to insert the red lead.. do you insert it in the cable from the power board that goes to the logic board?
Thanks again guys!
Thanks again guys!
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
