D-Link DI-604 router
  • andlcs
    • Feb 2007
    • 22
    My D-Link DI-604 router HW B1 had a capacitor bulging and leaking a little bit (I saw it after 2 years 24/7 usage). Unfortunately I don't remember the capacitor manufacturer. All I remember is that it was rated for 85oC. The router was still working even with the leaking cap.
    You can see it on the top left corner. The big electrolyte capacitor.
  • shadow
    • Feb 2007
    • 732
    Re: D-Link DI-604 router
    Soooo....do you have this router?
    If you do have it then couldn't you just pop it open again and see what capacitor is there. The thing that you really need to know is the rating in micro Farads. That way you can easily just pick up a top quality Japanese capacitor and solder it in.
    • andlcs
      • Feb 2007
      • 22
      Yes, I still have it. But I've already changed the capacitor and added few heatsinks too:
      • PedroDaGr8
        • Oct 2006
        • 130
        is that SC the new cap? That is a known bad cap company.
        • andlcs
          • Feb 2007
          • 22
          Humm thanks. I'll replace that one too...
          • etnietering
            • Apr 2009
            • 379
            Re: D-Link DI-604 router and DI-524
            Well for a couple years I had been using a D-Link DI-524 wireless broadband router, first at home and then at school. Last fall up at school, it would start dropping wireless connections randomly, which was annoying. I opened it up, and (not knowing capacitors could go bad at the time) didn't see anything wrong. So I spent 80 bucks and bought a new router (this new one's gigabit though ). Recently I found the old one, and took it apart again. What should I find, but bulging and vented capacitors!
            11 Electrolytic caps, all from the "Forever" brand. Looks like they didn't last forever...
            The two closest big ones to the camera have bulged, the one on the right vented through the stamp at the top
            Nice shot of the Forever logo...and check out that depth of field! hehe
            And here it is after replacing all of the electrolytics:
            4x Forever 1000uF 10v -> Panasonic FM 1000uF 10v (and my size measurements were wrong...oh well)
            7x Forever 100uF 25v -> Panasonic EB 100uF 25v
            And to my utter amazement, it works! The transplant surgery took my and my friend about 3 hours, from 1am to 4am....just a tip - don't ever try to recap something in the middle of the night, it will just lead to a lot of swearing and soldering iron burns.
            • Krankshaft
              • Jan 2007
              • 2328
              Hehe that board is a double sided PCB with through hole vias. It takes a bit of practice to remove the caps and install new ones on these boards quickly.
              Nice job!
              Apparently those caps didn't last "Forever" .
              • yanz
                • Nov 2004
                • 910
                but it will be remembered for forever that it is crap.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  these caps will be crap... forever
                  i once had a siemens speedstream wireless-b router that never had issues. i was bored amd opend it, found one bulged tocon, 6 tiny tocons with the bungs shoved completely down and outside of the cap- at first it looked like the caps were mounted on rubber bases until it dawned on me that the thing had no good caps inside. at least i got a pc card out of it
                  sigpic
                  (Insert witty quote here)
                  • MORETTIGIAN
                    Capacitor detached from PCB – RTX 2070 Super Founders Edition
                    by MORETTIGIAN
                    Title:
                    Description:
                    During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                    I did not notice it detaching, so I am unsure of its original location on the PCB.
                    Procedure performed:
                    - Removed backplate
                    - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                    - Reapplied thermal compound
                    - Reassembled card
                    Observed behavior after reassembly:
                    - GPU powers on and operates normally under...
                    09-18-2025, 12:14 PM
                  • Prolog
                    RTX 3080 FE Identifying capacitor
                    by Prolog
                    Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                    I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                    I hope these photos make it clear which component I am referring to:
                    (yes, the soldering is a bit botched from removing the blown one, I know)
                    I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                    12-01-2024, 08:27 PM
                  • double_DD
                    Why does my ISP router hate my "homemade" power supply??
                    by double_DD
                    It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                    So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                    For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                    07-12-2025, 03:09 AM
                  • Agent24
                    Dick Smith Q-1760 linear power supply filter capacitor question
                    by Agent24
                    I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                    It has at least one problem.
                    The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                    I have already ordered a replacement potentiometer, so that's not an issue.
                    Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                    All are CapXon...
                    10-21-2025, 05:39 PM
                  • chth96
                    If I replace with inferior capacitor, Is it No harm to other IC components at all?
                    by chth96
                    I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                    Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                    It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                    So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                    I know that these capacitor will not last as long as nichicon capacitor...
                    12-22-2023, 04:34 AM
