Dreambox 500 & 5620 fix for vertical horizontal LNB DiSEqC switch problem (long read)
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    I've been using a Dreambox for around 8 years now and it's very nice once you replace the built in software with third party images. (aka firmware)
    The hardware is another matter though...
    The first box I bought; A Dreambox 7000S has worked very well.
    All I've had to mod in it is add some capacitors to fix a YUV problem with the YPbPr video output (Pink line in the picture)
    My parents and also a friend of mine own a Dreambox 500S though, I wont give it as high points.
    I have had to replace both their external power bricks when they where only 2 or 3 years old: https://www.badcaps.net/forum/showthread.php?t=3917
    In my parents box I have also replaced some tantalum caps around the network controller because Dream Multimedia who builds these things used the wrong capacitance on the original caps through several models of Dreamboxes!
    I have had to fix several others Dreamboxes aswell.
    Circa two years ago a friend to me who owns a Dreambox 5620S told me he had changed everything, DiSEqC switch, cables and the dish however the box would still not show channels with Vertical polarization.
    Horizontal worked fine though!
    I had a look through the chassis grille and saw a bulged capacitor...
    I brought it home and there where two bulging Wendell 2200uF 10v capacitors.
    One on the rightmost side of the mainboard next to the PSU, the other on the opposite side right next to the tuner.
    After replacing both these the box worked great again!
    A few months later another friends Dreambox failed, same model and same problem. I replaced his Wendell caps with brand new Samxon caps aswell and it too worked fine after this...
    Then a few months later his box would no longer power up, the diode on the front just blinked and it made a kind of electrical switching noise when trying to start.
    This problem I know very well; I opened it up and replaced the small "startup cap" next to the input bulk cap on the PSU and then it worked great again
    And as history has a way of repeating the first friend came to me with exactly the same problem with his box, so I replaced that same cap in his 5620's PSU aswell and then it worked fine too!
    But one thing all these Dreamboxes share in common is that if you read online a specific brand of DiSEqC switch is recommended (and for good reason)
    It is called Spaun SAR 212 WSG (Or 411 if you need 4 satellite positions)
    For all Dreamboxes I have ever seen in the end the original DiSEqC switch has "failed" and replacing it with this Spaun switch has made things work again.
    However very recently both my parents and my friends Dreambox DB500 boxes have developed a fault very similar to what I described above for the DB5620.
    That is they don't want to show channels with Vertical polarization & they also get "stuck" on one LNB head and don't like switching...
    And they always manage to cold boot fine into one LNB, and then you can also switch to the other LNB without issue.
    However when you try to switch back to the previous LNB it does not switch...
    I even measured it with a multimeter and the DiSEqC switch really does not switch it's outputs....
    So I swapped his DiSEqC with my own (Also a Spaun) that I know works but the problem remained.
    So I did what I have done with the 5620 Dreambox; I replaced 2x capacitors that power the tuner and BAM both of these stupid little Dreambox 500S now work great!
    C721 & C728 are the cap positions, 47uF 25v & 100uF 25v respectively.
    You can see them on the rightmost side on my attached picture (Sorry that they are a bit out of focus, you can also see the network fix on the opposite side of the picture above the ASIX network controller)
    I replaced them with a Sanyo WX 47uF 50v and a Rubycon ZL 100uF 25v.
    Even though the original caps are OST RLG & some other crap cap named S.I. which are general purpose and not even low ESR...
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Dreambox 500 & 5620 fix for vertical horizontal LNB DiSEqC switch problem (long r
    I did the network fix to the DM500S that had not had this fix done yet today.
    When I did the other box a year or three ago I bought the Tantalum caps anyway to be able to do this one aswell and I actually managed to find them now
    They are 4.7uF 16v Tantalum caps
    Elfa Sweden sells them with partno: 67-765-12
    I also replaced the 33uF 16v bulk capacitor next to the ASIX network controller with a 470uF 16v Samxon
    Box really works great now
    As an aside the capacitance of the original electrolytic cap was fine but it's ESR was 65, so that probably explains how good the "S.I" brand caps are
    I attached a PDF (not by me) that describes the network fix and what the polarity of the caps is...
      Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
      This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
      09-06-2024, 05:30 AM
    • Natob82
      Micro Momentary Push Switch?
      by Natob82
      Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
      12-21-2022, 05:22 AM
    • grimacelord
      NEC TurboExpress On/Off Power Switch Replacement Help
      by grimacelord
      I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
      I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
      I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
      11-09-2023, 09:49 AM
    • SluggerB
      Help making a switch work the opposite way with a relay
      by SluggerB
      I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
      I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
      It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
      02-07-2025, 07:57 PM
      Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
      by sam_sam_sam
      Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
      ( needs more cam circuits for the machine to work correctly again )
      https://www.ebay.com/itm/275321870186
      To
      3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
      ( not 4 positions but the right amount of cams circuits )
      https://www.ebay.com/itm/274660439950
      I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
      03-18-2023, 05:12 PM
