Dell E152FPb
  • Korpsicle
    Audiophile
    • Jan 2012
    • 11
    Dell E152FPb
    Noobie Incoming.
    I got this monitor from a friend that had some flickering issues. Thwacking it worked, but after a short time the unit will light up the power button, but an image will never present.
    So I ripped it open and have board ETL-XPC-801
    And thus, I am here.
    Any help would be appreciated. It looks like the caps in picture 3 might be bad, but I'm not sure if there's something else that might be bad.
  • smason
    • 1652
    Re: Dell E152FPb
    You will need to upload the photos here, use the manage attachments button below.
    Many won't go to off site photo hosting sites, because they can (and recently have) contain malware.
    • Korpsicle
      Audiophile
      • Jan 2012
      • 11
      Re: Dell E152FPb
      My apologies. I figured an album view would be easier is all. Also they were taken with my iPhone in HDR so they're large files.
      Edit: Ran into sizing issues, pictures were over 2k pixels, attached to post 1.
      • PlainBill
        • Feb 2009
        • 7034
        Re: Dell E152FPb
        These monitors are notorious for a number of problems, but first let's clarify the problem. At present, do you get any sign of backlights?
        If there is no sign of backlights, can you see a faint image if you shine a bright light on the screen while the monitor is hooked to a working computer? If you can, you are a victim of crappy solder.
        Heating and cooling cycles cause the solder around the two transformers to crack and give intermittent contact. This causes either the transistor pair Q759, Q760 or Q739, Q740 to short. This blows picofuse Pf761 (PF751?). Q751 and Q743 may also be damaged.
        Check the picofuse to see if is open. Check all of the above transistors for shorts. Complete kits of parts are available on eBay.
        PlainBill
        • retiredcaps
          • Apr 2010
          • 9271
          Re: Dell E152FPb
          This is the standard Benq board with multiple potential problems.
          1) All the components circled in red MUST be resoldered or reflowed due to poor solder joints. MANDATORY. If you ignore this step, don't be surprised if your monitor dies again.
          2) All the components (transistors and fets) circled in green should be checked for shorts.
          3) The picofuse is circled in yellow. A good fuse should measure less than 1.0 ohms.
          4) PlainBill beat me by 3 minutes while I was doodling in paint.
          5) And smason is correct. I won't even bother to look at pics hosted offsite.
          --- begin sig file ---
          --- end sig file ---
          • PlainBill
            • Feb 2009
            • 7034
            Re: Dell E152FPb
            Yeah, I've got some apple crisp calling to me from the kitchen.
            PlainBill
            • Korpsicle
              Audiophile
              • Jan 2012
              • 11
              Re: Dell E152FPb
              Okay, well I've good good and bad news. Mostly bad news. The screen is working fine now that everything is plugged back in.
              But it was doing this before. It would work fine, then it would flicker, I'd hit it and it'd turn back on, then it wouldn't even flicker and I gave up. This is was a couple weeks ago. I hooked it up a few days ago and it just worked, had to hit it once I think yesterday, and then today it just wouldn't try. Which is why I took it apart.
              @Both I don't have access to my multimeter, I took it to work today and forgot to bring it home. I'll have to try that tomorrow when I get home from work.
              @retiredcaps
              1) My soldering iron needs new points I can pick them up tomorrow and I'll do that.
              2) When you say check for shorts, what kind of readings should I get at what settings?
              3) again, sorry to sound so helpless, what settings should I run at.
              • retiredcaps
                • Apr 2010
                • 9271
                Re: Dell E152FPb
                See
                https://www.badcaps.net/forum/showpo...4&postcount=19
                specifically the section on Multimeter, 2) Shorted Transistors/MOSFETs, and 3) Open fuse.
                However, if your monitor is working, it is likely the poor soldering causing your grief. If resoldering doesn't solve the problem, it could be caps with high ESR (ohms). ESR drops as the monitor warms up and allows the lcd to work.
                • Korpsicle
                  Audiophile
                  • Jan 2012
                  • 11
                  Re: Dell E152FPb
                  Well that's good news.
                  Would it be easier to reflow with a heatgun from my station? Or check for cracked points and re-solder? I also have a small oven I frequently reflow X360's with at my disposal.
                  Edit: also, thanks for the link. Bookmarked
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    Re: Dell E152FPb
                    Use a solder iron and reflow or resolder each of those circled components works 100% of the time. No baking is required.
                    I made the mistake of not resoldering/reflowing the inverter transformer and in about 25 hours, I had a blown picofuse again. It was my first repair of a Benq board. Now I have done 5 or 6.
                    • Korpsicle
                      Audiophile
                      • Jan 2012
                      • 11
                      Re: Dell E152FPb
                      Oh cool. Thanks a ton. I'll be sure to do that in the morning then and will post with results.
                      • Korpsicle
                        Audiophile
                        • Jan 2012
                        • 11
                        Re: Dell E152FPb
                        Well I tried re-soldering some of the connections however upon power on the image turns on for a second or two and the backlight goes out. I can still see an image very faintly on the screen.
                        • trebo
                          • 514
                          • Wales, UK
                          Re: Dell E152FPb
                          have you resoldered all the components that retiredcaps circled ??
                          you may have had a failing ccfl that has completly failed now
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            Re: Dell E152FPb
                            Time to troubleshoot using the multimeter as per posts #4 and #5.
