Schematic for Antec Truepower 330 and other PC PSU's
  • redwire
    • Dec 2010
    • 3910
    I need a schematic for an Antec Truepower 330. I was recapping it and got mixed up, as a 47uF tested 200uF and one burnt. If anyone has some scribblings it would be appreciated.
    While searching, I found many PC power supply schematics at this site, although it is Russian, there is good stuff here:
    http://electro-tech.narod.ru/schematics/power/comp.htm
    Especially many 5VSB schematics, good bad and ugly.
  • Toasty
    • Jul 2007
    • 4171
    Re: Schematic for Antec Truepower 330 and other PC PSU's
    Welcome to the forums redwire.
    Best wishes on schematics. Not likely unless someone happened to draw one of that model. All are proprietary and not released. Remember, these units are considered "not serviceable" and schematics would be "in-house" only.
    Best bet here is to photo your unit's board(s) top down and some side angle shots and post here. The unit is probably similar to the 300w or 350w TruePower units and parts were -usually- the same or similar.
    Indicate what you need in the pictures and see what the people here can tell you.
    Toast
    veritas odium parit
    • redwire
      • Dec 2010
      • 3910
      Thanks Toasty, here's some pics of the PSU, with somes caps taken out.
      The one cap I'm not sure about is C38, part of RC network on TL431 cathode-reference that appears to monitor 3.3V rail. It might be 10uF 50V? with 3k6 in series. The fan control transistor baked it.
      If anyone can take a look in their junkbin, that will help
      • Toasty
        • Jul 2007
        • 4171
        1uF 50v
        That's on a TPII-480 Blue with C38 in the same position. In these they moved the fan control to a small daughterboard.
        Let's see how close they match:
        From the bottom on pic # 3:
        - Just below the 5v wire bundle should be a 1uF @ 50v, 5x12
        - Just above the 5v bundle should be (4) 4700uF @ 10v, 10x35
        {the lower 2 and the black wrapped coil are the 5v pi filter}
        {the upper 2 and the "bare" coil are the 3.3v pi filter}
        - Above and left a bit is C38, 1uF @ 50v
        - Above the fan control transistor are (2) 3300uF @ 16v, 10x35
        {they are with the coil above them forming the 12v pi filter}
        Make sure you replace all the Fuhjyyu caps on that board. There should be a 10uF @ 50v cap down near the mains caps that is -critical- to the 5vsb circuit. It's right on the board edge. If it fails, the 5vsb will fail and take the mobo with it.
        Seems silly to chase such small caps, but this manufacturer is Krapola.
        HongKongFlyApart Co., LLC ®, is actually better.
        Toast
        veritas odium parit
        • redwire
          • Dec 2010
          • 3910
          Okay, that's pretty close, the TP330 is a CWT-550AD with some smaller parts (i.e 3300uF vs 4700uF, and 1650uF vs 3300uF).
          Your notes help a lot, everything matches except cap C3 (on the board corner near the mains caps) I have as a 1uF/50V that traces back to the PWM IC soft-start.
          So I'm still wondering where the 10uF cap came from. Never watch TV or answer the phone when recapping...
          What do you have on the PCB corner by the 5VSB/-12V wire bundle?
          On the top edge, near heatsink 1000uF/10V C19 then C37, C7. Below C19 there is C31 and then C32 by the big inductor. I had 100uF and 220uF for these.
          • Toasty
            • Jul 2007
            • 4171
            >>Never watch TV or answer the phone when recapping...<<
            LOL Actually, making a cap map is what you should do as you pull them.
            >>What do you have on the PCB corner by the 5VSB/-12V wire bundle? <<
            That's where mine differs. 5vsb, fan control, and the others come off the daughterboard that I mentioned before. I can't help there.
            I am surprised no one else has chimed in here...
            I'm certain more than one of these has been recapped by a member or two.
            Toast
            veritas odium parit
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              The smallest TP I remember seeing was a 400 or 450 and as you said they as different.
              I've seen smaller SP's but not TP's.
              Mann-Made Global Warming.
              - Dr Seuss
              • TinkerTron
                Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                by TinkerTron
                Hey everyone,
                I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                Instead, here's what's been bugging me so far:
                The schematic...
                03-06-2025, 02:03 PM
              • atunguyd
                Acer x163w Monitor PSU schematic
                by atunguyd
                Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                03-05-2025, 02:08 PM
              • Thetechdude
                MSI Ventus RTX 4080 16G Broadview schematic needed
                by Thetechdude
                Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                Thanks.
                07-15-2025, 11:15 AM
              • ianpoultonknights
                Zenbook Flip 15 UX562AI schematic
                by ianpoultonknights
                Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                06-26-2025, 02:41 PM
              • Much Bugs
                MSI Z390 A-PRO Schematic and BoardView
                by Much Bugs
                The Schematic and BoardView( *.cad ) of MSI Z390 A-PRO , the board model no is MS-7B98 Rev1.0-1.1 ....
                06-24-2025, 10:13 AM
