Corsair CX430
  • Phaedrus2129
    • Dec 2010
    • 3
    Corsair CX430
    So in case you don't know someone pulled a CX430 off the shelf and did a technical analysis and showed that it is a massive piece of garbage. Most importantly, the rectifying bridge has no heatsink, and without a heatsink is only rated for 3.5A, or 402.5W (assuming 115VAC mains), which factoring in efficiency makes it about a 300W power supply. Plus the primary cap is a 180uF wonder from SamXon, a cap I'd expect to see in a 250W PSU. The secondary caps are mostly SamXon as well, with one Teapo and one Jun Fu.
    Naturally, many enthusiasts who thought this was going to be another decent mid-range unit from Corsair are disappointed and want to mod their PSU for $20, rather than buy a brand new one. The design isn't bad, DSAII is a decent platform, it's just that Corsair cheaped out on components.
    So my plan for "fixing" the CX430 is:
    - Attach heatsink to rectifying bridge
    - Replace primary cap
    - Replace secondary caps
    Now a heatsink is no trouble, and the secondary caps should mostly be able to be replaced by Rubycon PX caps, but I'm not sure on the primary cap. I think a Rubycon MXC should do it, >250uF. I'm not sure of a good source for them though. I found one place selling a 330uF one for $5, but I don't know anything about them: http://www.newark.com/jsp/search/pro...FC-GB100000001
    Any good source for MXC caps? And any other advice on how to improve this overrated disgrace?
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Corsair CX430
    Rubycon PX are not low enough ESR.
    - In fact they aren't low ESR at all. - They are GP caps.
    Output filters are 'tuned' to optimize filtering at a certain frequency and the value of the inductors, the caps uF, and the caps ESR are all take into account when the designer specs the caps.
    Look up the specs for the old caps and find caps that match closely or your mod may well result in MORE Ripple in the output by de-tuning the filters.
    Mann-Made Global Warming.
    - Dr Seuss
    • Phaedrus2129
      • Dec 2010
      • 3
      Re: Corsair CX430
      Ah, research fail.
      • Phaedrus2129
        • Dec 2010
        • 3
        Re: Corsair CX430
        Well, is the MXC still a good fit for the primary then? I've seen MXGs in a couple other power supplies, and the specs look similar. And I may go Teapo on the secondaries to save some money.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Re: Corsair CX430
          Primaries are not low ESR so look up the Ripple for old cap, look up Ripple for MXC, make sure it is measured at the same frequency, if not the same frequency adjust the Ripple on one of them by amount given in data sheet so the Ripple -is- for the same frequency.
          After all that if the MXC's Ripple is the same or more than the old cap it is a suitable replacement.
          [Sounds like a lot but it isn't that hard.]
          - Dr Seuss
          • weirdlookinguy
            • Sep 2007
            • 1638
            Re: Corsair CX430
            Teapo is worse than Samxon. Not much of an improvement there.
            Good japcaps are cheap, why do you want to save money?
            • 370forlife
              Large Marge
              • Aug 2008
              • 3113
              Re: Corsair CX430
              Where does one buy teapos? Samxon is above teapo, anyways. Might as well just get samxon RS from topcat here at badcaps, they're cheap. 10v/3300uf and 16v/3300uf in 10mm diameter, but check the ESR and ripple specs as to what samxon's are already in the corsair.
              • Rulycat
                • Apr 2010
                • 724
                • United Kingdom
                Re: Corsair CX430
                I've seen some floating around on eBay, but the ones I've seen pictured lack the little indents in the vent that teapos have, so someone seems to have been copying Teapos.
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  Re: Corsair CX430
                  I get Teapo for free from old psus.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Re: Corsair CX430
                    I saw some that were over ten years old.
                    - Dr Seuss
                    • Rulycat
                      • Apr 2010
                      • 724
                      • United Kingdom
                      Re: Corsair CX430
                      I don't know why anyone would want Teapos...
                      • mockingbird
                        • Dec 2008
                        • 5484
                        Re: Corsair CX430
                        Corsair has really upset me with their new "GP" series power supplies which deprecate their excellent "VX" series.
                        The GP use Samxon "GF" capacitors, which are garbage, but I have already seen a review on a Chinese website where they said something to the extent of "Samxon caps - good, but not the best", when in fact, GF series are just about as 'good' as Capxon or Teapo - which is to say - not very 'good' at all.
                        Money money money, more business is better than good business, this is how these companies fall.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5072
                          • New Zealand
                          Re: Corsair CX430
                          I thought Corsair were smarter than this. This is a stupid move
                          -David VanHorn
                          • eryjus
                            Heathkit IO-4205 Power Supply Caps
                            by eryjus
                            First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
                            I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
                            I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
                            05-10-2023, 11:21 AM
                          • Paxman_Swede
                            Identifying caps on an old Zoom 9000
                            by Paxman_Swede
                            Hello!
                            I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
                            The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
                            I have studied the board and...
                            01-14-2025, 09:51 AM
                            by momaka
                            03-15-2023, 10:17 PM
                          • captain150
                            Help with switching power supply caps
                            by captain150
                            I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
                            I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...
                            03-16-2025, 07:34 PM
                          • Foetuss
                            Gigabyte GA-6OXT :: caps question
                            by Foetuss
                            Good evening
                            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                            But I was also suprised about the bigger boys, which are 330µF 25V.
                            Could it be they used 25V caps because they were cheaper / available at that time?...
                            02-11-2025, 12:22 PM
