Old 09-10-2010, 03:10 PM   #1
PowerAmpFreak
City & State: Europe
My Country: Sweden
Line Voltage: 230VAC 50Hz
Default STK795-811A vs YPPD-J014C?
Hi all.
I'm about to replace the Y-SUS hybrid in a LG PDP42V7 and the original is fitted a YPPD-J014C. I read that the STK795-811A is eqvivalent aswell.
Is there any major quality differences between the parts?
Is the STK better than YPPD and may it cause some problem to substitute the YPPD with a STK?
PowerAmpFreak is offline   Reply With Quote
Old 09-10-2010, 08:22 PM   #2
cadiman
City & State: chesterland Ohio
Default Re: STK795-811A vs YPPD-J014C?
On the ones I replaced I chose the stk over the yppd. I had the red speckles a few other people have talked about. The picture was still good, but I think there were other problems with the y drive I couldn`t find ( It was my first L/G (vizio) Make sure to check the power supply feeding the IC. The old IC would run about 145 degrees. I would check all the caps in the area around the IC.
These had bad caps on the 15 to 18v supply feeding the yppd.
cadiman is offline   Reply With Quote
Old 09-11-2010, 02:02 AM   #3
PowerAmpFreak
My Country: Sweden
Something tells me to stick to the original device.
God knows what may differ between the STK and YPPD and eventually result in sparks or similair.
Thanks for the info the check surrounding capacitors close to the hybrid.
Old 01-13-2015, 07:57 PM   #4
paulstef
paulstef's Avatar
City & State: Quebec
My Country: Canada
Line Voltage: 120VAC
I know, old thread.
I have a blown YPPD-J014C as well, didn't check any caps yet. When replaceing this hybrid is there anything else I should worry about apart from electrolytic caps?
Other power semiconductors on the board seem to be ok.
paulstef is offline   Reply With Quote
Old 01-28-2015, 07:02 AM   #5
paulstef
paulstef's Avatar
My Country: Canada
Originally Posted by paulstef View Post
I know, old thread.
Replacing only the YPPD-J014C works just fine. No other components were damaged...
