I have another Toshiba A500 . PSAR3A-026002
KSKAA LA-4991P Rev. 3.0 mainboard
2 x 2GB PC6400 DDR2
P8800 2.66ghz 3M cache Core Duo.
Purchased broken, advertised as broken screen but in fact had broken fascia glass and broken LVDS cable, screen is good , display was all lines but external monitor works fine.
Initially I had an issue getting it to boot to bios, usual RAM swap got it going. I was in 2 minds whether it was the stick or slot but ran with 1 and eventually I tried both slots and it seemed ok.
using an external monitor, loaded OS(W7) and was ok except it became a nightmare finding Digitally signed drivers.
Then I was going to try Vista instead and somewhere along the line it started having issues like getting to splash screen and just stayed there, suggesting it was still loading. The HDD light was not active.
I tried Hirens mini xp, it does the same as windows.
It will run linux and DOS programs from Hirens.
I can get into bios and change settings.
I have tried loading defaults and also disabled dual core, no change.
have tried 8 sticks of RAM including a known good set from another A500.
have tried 4 different HDD.
Memtest 86 runs in Dos, no errors with 2 simms installed.
it seems quite apparent I'm looking at MB issue and I 'm thinking it's along the memory addressing but honestly not my area of great knowledge.
I did on one occasion fluke getting Hirens mini XP up after about 2 hours of RAM swapping etc, but once I remaoved that piece to the alternate slot, back to the same problem, going back again to the first slot, no good . spent hours again tryin and could not replicate it working again.
It's frustrating it almost works but not where it needs too. Hoping there's a chip that's replaceable rather than the whole MB.
Also, have swapped the P8800 with a T6500 CPU 2.1 known to be good, no change.
there's a possibility this has had moisture ingress or been in a moist environment as I'm seeing a white build up between the legs and pins of devices on the board. I've had one go with a brush and alcohol, but no luck there.
Sorry, but I'm clueless again
2 x 2GB PC6400 DDR2
