Hello, I need help figuring this one out.
I'd appreciate any help.
My 42" Vizio GV42LHDTV has two symptoms.
When turning set on it (any input source) it will not respond to any commands from remote or side panel buttons for about 30 - 40 seconds (ie: volume control, channel changes, input selector changes, menu, etc. The second symptom is that it does not receive digital tv channels. In menu when scanning tv channels it will scan analog ok, then it will not attemp to scan the digital channels at all, just stalls. If I input a digital channel manually it just blinks and I get a blue screen. All other inputs and functions work as expected. For now I watch OTA tv through the composite input using a set top tuner.
All DC voltages from power supply check ok. No swelled or leaky caps.
All Voltage regulators on main board check ok. So I bought a replacement main board. Put new main board in and same exact problems.
Does anyone here have any ideas on this problem?
Could a bad T-Con board be causing this even though I have no backlight or video scanning problems?
