I have a board with fb01 fb02 fb03 ect. Fuse?
Does FB mean fuse also?
Re: Does FB mean fuse also?
Whoa!
Dark grey SMD of this type are ferrite that has physical characteriscs that filters DC of (blocks) noise and is NOT a fuse. And does not have a marking on it to state the fuse current rating. Like a letter, or a number even a number with "A" on the end.
Have to be careful with the location marks. I have seen different markings like FSxxx, etc, CV, QV etc, even TVxxx lately that could mean anything for component locations (transistor, resistors, diode etc).
Cheers, Wizard
http://www.garrettelec.com/div_detai...ite%20bead.cfm
Like these? I stand corrected. They had continuity so I ASSumed.
USB usually have fuse of some types, two types actually. One that is thermal resettable fuses that opens up when it get too much current. Remove current and cools off, conductivity restored. Cheap boards had one time fuse that blows and you are SOL.
The crummiest boards have none and is dangerous to have (insurance adverse and fire hazard).
Cheers, Wizard
