Sure enough, diode 4 is conducting in both ways - that means it is shorted!
What is the part number on the diode bridge?
The NTC is also good - it looks like the bridge just has one shorted diode, and it seems the MOSFET isn't shorted, so I assume that the bridge rectifier was the only problem. It has no heatsink, and there are dust marks around it which sugguest that it gets hot. That would increase the likeliness for failure.
"2. Do you get about 325 volts DC on the big filter capacitor? How would i test this? There is very little room for multimeter probes"
If there is space insulate the heatsink with tape and use small crocodile clips on the cap legs. Otherwise you will have to test on the back. you may not need the main board connected for this. If you still cant get at it you will have to solder wires to the joints then check those Extreme care as there could be 400 volts involved.
