Acer Aspire 5750 no B+ voltage
    Hi, i have 19v on pq7 but only 1v output thus no 3.3v nor 5.0 v always voltages and the system is dead at the moment. in the attachment i measured the voltages at start of the B+ rail. Any advices welcome
    Motherboard model is P5WE0 LA-6901P REV 2.0
    Re: Acer Aspire 5750 no B+ voltage
    Measure the voltages on pins 1, 2, 8, 23, 24 of PU1
    Measure the voltages on all the pins of PQ14
      Thanks for the reply
      pu1
      1=5.1v
      2=1.35v
      8=0v
      23=0
      24=18.5v
      PQ14
      1=0v
      2=0v
      3=0v
      4=0v
      5=0v
      6=6.1v
        u must have short to ground on B+ rail
        remove all PJP and check which powerrail is shorted
          i thought of that and shorted the pin 1 and 8 of PQ7 but there was no short. But after your message i tried to short 1 and 8 pin of pq7 but this time with 19v and the motherboard worked ok. Thus i changed the pq7 with the new one but still output is 1v, very strange
            Measure the voltages on all the pins of PQ19
              check resistance to ground on pin 5-8 on pq7
                PQ19
                1=2.6v
                2=0v
                3=ground
                  Resistance is reading in mega ohms so definetely no short
                    did u use exactly the 4407?
                      it was 4459 and i used 4435 instead
                        on your picture it is 4407
                        but 4459 can handle TRIPLE current than 4435 so u probably burn that 4435
                          this board is rev 2.0 4407 is in the rev 0.1
                            no its not burnt still output is 1v
                              pu1
                              1=5.1v
                              2=1.35v
                              8=0v
                              23=0
                              24=18.5v
                              PQ14
                              1=0v
                              2=0v
                              3=0v
                              4=0v
                              5=0v
                              6=6.1v
                              You have 19v and acset voltage to the charger but not acprn signal. Replace charger ic. I always replace and the fets, so I suggest replace and pq15 and pq16
                                changed charger ic but there was no difference. so charging i is ok. any other advice?
                                  Measures PQ19 taken according to this numbering?
                                  See Annex
                                  Voltages do not add up
                                  Considering the numbering as an attachment
                                  PQ19 pin 1 connected to pin 23 of PU1 (0V correctly stated)
                                  pin3 PQ19 (must essera to about 3V) connected to pins 2, 5 PQ14 (0V incorrectly stated)
                                  Pin 2 to ground PQ19
                                  Check that the pin 2 of 3 PQ19 are not short.
                                    I posted without reading ISL's datasheet. ACPRN should be low.
                                    What is the voltage on pin 4 of PQ6 and PQ7? What is the voltage on pins of PQ14?
                                      See attached first post
                                      pu1
                                      1=5.1v
                                      2=1.35v
                                      8=0v
                                      23=0
                                      24=18.5v
                                      PQ14
                                      1=0v
                                      2=0v
                                      3=0v
                                      4=0v
                                      5=0v
                                      6=6.1v
                                      Here are the steps required
                                        See Annex
                                        i've checked PQ19 but only 1 pin is shorted to groun other pins are not shorted
