Today I picked up an old (2001) Kodak MC3 Video camera/mp3 player for $2.
It didn't work when I got home... it would flash the power light once when I gave it battery power.
I opened it up in a fashion similar to an EEVBlog Teardown Tuesday (no "Crazy Aussie Bloke" accent though ) and found a tiny SMD battery one one of the daughterboards... an MS621FE-IL36E.
It's rated for 3V, this one was putting out 1.1V . I got the idea that this one sat w/o AAAs for a long, long time.
While it may be a rechargeable cell I get the idea that it's toast if the output voltage was that low (right?).
It uses an apparently hard to find battery... The only place that even lists it is Digikey:
http://www.digikey.com/product-detai...36E-ND/1630704
The similar version (different lead layout, same coin cell) is the MS621FE-FL11E:
http://www.digikey.com/product-detai...057-ND/1889208
I have 3 choices:
1. Request the original part. I have a bad feeling it may be out of production or that I'd have to order 1000+ of them for them to go back in stock.
2. Buy the other part, snip the positive lead, and solder on a thin wire to simuate the missing lead. My concern here is that the solder may not wick since only the ends of the leads are tin coated.
3. Other.
Anybody have some advice here?
I have 3 choices:
3. Other.
