This has been a weird issue that I ghave brought up here before in another form and started at some point while I was first setting up my computer and installing software and drivers this time last year. I don't remember when exactly during the above job it started so don't ask what I last installed. The following is what I gathered over several months of observation.
8/10 times when you boot the system up (warm or cold) and you log in the first thing you will notice is that the audio is terribly garbled. After the system has finished logging you in and has loaded everything you will notice you are idling between 15 and 35%. If you try to play an audio file, it will still be garbled. If you play a video, the video will be laggy and the audio will be garbled.
Games, flash, the screensaver and pretty much anything else multimedia is just sluggish and unusable.
If I open the task manager I'm able to see where 50% at most of the processor usage (not including the idler process) is coming from. For the rest I need to run Microsoft Process Explorer and I'll see the rest of the processor usage being tied up in interrupts of all things.
From here on two things will happen. Either the system will lock solid eventually and need to be rebooted or after a random amount of time the idle will drop back to normal (between 0 and 5%) and everything will run smoothly again until you restart the system. I noticed that once the system returned to normal the processor usage taken by interrupts drops from up to 30% down to 3% at max.
From my knowledge on what interrupts are, something is firing off interrupts unnecessarily (if it was fine before things started to get installed it could be a bad driver or piece of software but a hardware fault is not likely) and it is choking the system.
Can I get some assistance tracking down the source of the fault and killing it once and for all? I can already rule out a reinstall as the problem persists after a clean reinstall.
