I replaced the bad 15uF, 200V capacitor in an under-counter 15W fluorescent lamp with a 20uF, and now the fluorescent tube glows violet at both ends. Too much voltage? Too much ultraviolet?
Fluorescent electronic ballast
Re: Fluorescent electronic ballast
bad lamp?Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.
the cap that went bad may have damaged other things because in my knowledge (with analogue ballasts) if the starting circuit doest cut out the tubes will glow like that at the ends. it could also be that cap was in the starting circuit and the value is very important. like say a 20uF might be for starting a 20 watt bulb and a 15uF for a 15 watt etc. is this by any chance potted in tar and is the cap reversed?Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
