Dell 2005FPW monitor flashes red, green, blue and white full screens every two seconds. Tried to factory reset the monitor but the front faceplate buttons for reset does not work. How can I do a factory reset manually without using the faceplate buttons.
Dell 2005FPW monitor flashes red green blue and white full screens every two secs
Re: Dell 2005FPW monitor flashes red green blue and white full screens every two secs
Have you got a known working source connected - this could be one of dells selftest screens instead of displaying "NO Signal"
Is this a new to you monitor did it have any faults before.
What does the power light doLast edited by selldoor; 08-29-2012, 02:11 PM.Please upload pictures using attachment function when ask for help on the repair
Can you try another cable or try on another pc or laptop.
Do you have another monitor you can use to test the pc/card/cable
Failing that you will need to open it up and let us see the inside
Welcome to the forum-
We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
Examples of what is needed
https://www.badcaps.net/forum/attach...1&d=1290283049
https://www.badcaps.net/forum/attach...7&d=1280167246
It will be useful if you can say a bit about yourself - skills tools etc.Please upload pictures using attachment function when ask for help on the repair
Originally posted by rp2000 View PostThe monitor is connected to my desktop. I have been using this monitor since last 5 years.
The power button is lit all the time till I power off the monitor. The rest button does nothing when pressed.
Well done - I think I would have probably replaced all the middle range caps as they appear to be samyoung samwha and the like.Please upload pictures using attachment function when ask for help on the repair
