possible?
Making a atx12v power supply to test for short
Tags: None
Re: Making a atx12v power supply to test for short
Originally posted by macattack600 View Postpossible?
I want to push 12v through a pair of transistors but I need something on the positive end that draws power to feel the board get hot in a location
So, atx -12v rail to -transistor. atx-ground to ground on board.
I think ? and ground wire to something heavy 12v this idea work? The board uses transistors to turn 16v into 12v, there is a short to ground on the board.
so you want to blow the short or make it smoke?
that's going to do more damage.
anyway, most psu's wont let you do that, you need to use a bank of caps that you charge and then connect to the short.
then you will blow *something* but probably not what is shorted.
what you really need is a low-ohms meter, there used to be circuits to build an audio tone version using an lm3909 that will find shorts usually.Last edited by stj; 10-21-2014, 02:41 PM.
Originally posted by macattack600 View Postpossible?Originally posted by stj View Postso you want to blow the short or make it smoke?
what you really need is a low-ohms meter, there used to be circuits to build an audio tone version using an lm3909 that will find shorts usually.Last edited by macattack600; 10-21-2014, 05:19 PM. Reason: all it did was get very hot at the GPU...so replace!
