So, I have replaced a number of components on the power board of a TV trying to eliminate some high pitched coil whine. All caps are new, but the whine persists, so now I'm trying some of the other prone-to-failure components.
The Mosfet is a W18NK80Z, and this is the datasheet
I'm using an ebayed ESR meter / smart component tester
and an Ancor 702073 Multimeter to try and test it. When I put it on the smart tester, I get the following readings:
C=12.9nF
Vt=4.2V
and a proper identification of the 3 pins (Gate, Drain, Source). Is this enough to determine if the Mosfet is good? I have no idea.
Next, I used my DMM to try some of the tests I've read about online, including retiredcaps' methods. I get nothing with my meter set on 200ohms. If I set it on continuity/diode test, I get no reading except with the negative on Drain and the positive on Source, and I get a reading of .469
If I try this method with my DMM set on continuity / Diode tester, it does what it says it will on the page. Climbs from 1 to 1.9 and then is either giving me an infinity reading or resetting to 1.
Which of these tests confirms the Mosfet is good? Any of them? How come I don't get and readings with the DMM set on 200ohms?
Cheers,
Alex
C=12.9nF
Vt=4.2V
Cheers,
Alex
