Help reading a surface mount aluminum cap
    I accidently knocked it off the board and pins are too short to solder. The cap has the following numbers on top:
    14259
    68
    35K
    Is that a 35V 68uF?
    Re: Help reading a surface mount aluminum cap
    Is this electrolytic cap in silver color case?
      Yes the silver ones with the black plastic base
        I think you are correct about that value. Is there another one or two with the same labels?
          I think you can tell from the size & by comparison with other similar caps on the same board whether 68 is 68 microfarads. Most probably you're right if they are in silver case...as you said.
            Yes there are a couple others on there. I found the 68uF on digikey but looks like a 68uF 35V would be a rare one, so I wasn't sure.
              Measuring the cap shows it appears to be 68uF, so I'm guessing 35V and it appears "K" may be the tolerance code which should indicate 10% according to a web page I found. Thanks for the assistance Ill give it a try..
