Help reading a surface mount aluminum cap
  • kevinm34232
    • May 2012
    • 1884
    I accidently knocked it off the board and pins are too short to solder. The cap has the following numbers on top:
    14259
    68
    35K
    Is that a 35V 68uF?
    Re: Help reading a surface mount aluminum cap
    Is this electrolytic cap in silver color case?
    • kevinm34232
      • May 2012
      • 1884
      Yes the silver ones with the black plastic base
        I think you are correct about that value. Is there another one or two with the same labels?
        • Ahakim
          • Apr 2013
          • 64
          I think you can tell from the size & by comparison with other similar caps on the same board whether 68 is 68 microfarads. Most probably you're right if they are in silver case...as you said.
          • kevinm34232
            • May 2012
            • 1884
            Yes there are a couple others on there. I found the 68uF on digikey but looks like a 68uF 35V would be a rare one, so I wasn't sure.
            • kevinm34232
              • May 2012
              • 1884
              Measuring the cap shows it appears to be 68uF, so I'm guessing 35V and it appears "K" may be the tolerance code which should indicate 10% according to a web page I found. Thanks for the assistance Ill give it a try..
                Surface Mount Fuses Fundamentals Datasheet
                TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                10-07-2024, 06:07 AM
                Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock boardview and Surface Book 3 + Surface Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                09-06-2024, 08:10 PM
                Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock 2 boardview and Surface Book 3 + Surface Dock 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
