OCZ Vertex 2 panic mode
    hey guys, i have a 128gb ssd in panic mode... anyone have any ideas how to fix it? its not being detected by the BIOS and its clearly a firmware issue.
    Steps i have tried to fix it:
    Test in various computers - the Power and Activity lights stay stuck on.
    Desolder EEPROM - Well now i know its a firmware issue :P
    My next step would be to try and read the contents of the EEPROM and see what i find, might lead somewhere might not. it also has a TTL serial port but i dont have a RS232 to TTL converter so i cant use it.
    From what i understand i will either need to get the binary file somehow from the update utility or take it off an unbricked Vertex 2.
    Does anyone have any experience/help with these ssd's (its the old sandforce 12xx series with the sleep bug)
    Re: OCZ Vertex 2 panic mode
    well i just did a quick check and i couldn't do anything with windows updater (stupid downloader, typical)
    but there is bootable linux version that is 50mb heavy, i guess it includes firmware files inside, i couldn't extract it either on windows, but you can try burning it to thumb drive, booting up and check if you can then extract the dump
      Sounds like the board may be fubar.
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      16 GB AData XPG Spectrix D41
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
