Thread Tools | Display Modes |
#21 |
City & State: Canada
Good job. Thanks for supporting this site with your purchase.
__________________
--- begin sig file --- If you are new to this forum, we can help a lot more if you please post clear focused pictures (max resolution 2000x2000 and 2MB) of your boards using the manage attachments button so they are hosted here. Information and picture clarity compositions should look like this post. We respectfully ask that you make some time and effort to read some of the guides available for basic troubleshooting. After you have read through them, then ask clarification questions or report your findings. Please do not post inline and offsite as they slow down the loading of pages. --- end sig file --- |
#22 |
I know digging up posts is a bad thing, but I wanted to give a thanks for badcaps and this thread. I picked up a dead hp pavilion for free and found out this guy had the EXACT same caps go as the one I found! Must be one really big bad batch of caps. The time this board would have died is similiar to the OP.
Now I need to keep my eyes out for more easy fixes. |
#23 |
City & State: dayton ohio
i have 3 of these in the recap pile waiting for me.
came to the conclusion that the tk caps are junk. these were used in a industrial unit with an ac hanging on the cabinet.still blew up.in about 2 years too. |
#24 |
Unknown
City & State: North Coast, NSW
My Country: Australia
Line Voltage: 240V 50Hz
I'm a: Professional Tech
Just goes to show that the Japanese can make junk caps too. I have an aced at work from a customer. It has an entirely different board to this. Caps are a mixed bag of TK and sanyo. The TKs are bulging, but the others look fine.
EDIT: I always add fans to the chipsets on these boards too. Being nvidia chipsets, they need to be kept as cool as possible.
__________________
I love putting bad caps and flat batteries in fire and watching them explode!! Main PC: Core i5 660 3.33GHz, Gigabyte GA-P55-UD3R, 4GB Kingston DDR3 1333, 750GB WD HDD, Sony Optiarc DVD RW, nVidia GTX295 1760MB, Antec 1200 Case, Delta DPS-750CB 750W PSU, Hauppauge TV Tuner, Windows XP Pro. Main Laptop: Lenovo Thinkpad T60: Core 2 T2500 2GHz, 2GB DDR2, 80GB HDD, DVD RW, Intel Graphics, Windows XP Pro. 2nd Laptop: Toshiba Satellite A200: Core Duo 1.73GHz, 2GB DDR2, 60GB HDD, DVD RW, nVidia GF Go 7300 Graphics, OpenSUSE 12.2, Fan Mod Last edited by c_hegge; 08-15-2011 at 06:01 AM.. |
#25 |
Recap fixed intermittent blue screens, unexpected restarts, and noticeably just after waking from sleep mode. General unstable machine behavior.
Was in the process of looking for a motherboard replacement, then came upon badcaps.net and found a much quicker and cheaper solution to the problem. Purchased the kit (was on-sale) got 25 caps in all, arrived in two days. Thanks badcaps.net. Cap removal was pretty easy, but clearing the hole was more work, used the dental pick method outlined in the FAQ to push the solder out, iron on the bottom side of board, pick from top (component side) to push solder out the other side. Did it with board upside down, with memory SIMMs removed, but CPU and heatsink in place. The difficulties I had could be my iron was hot enough to distribute the heat on the hole, tried solder sucker bulb and wick methods both no joy. Replaced all TK brand caps, nine 6.3v 1800uf, three 16v 1800uf. Of the 6.3v; 4 bulged on top, 2 bulged and leaking on top, 3 seems okay. Of the 16v all three seems okay. Here are some of the Windows 7 Event Viewer logs which might be helpful to others: _______________ The previous system shutdown at 10:21:18 PM on 9/15/2011 was unexpected. _______________ The computer has rebooted from a bugcheck. The bugcheck was: 0x0000001a (0x0000000000041287, 0x000000000d230000, 0x0000000000000000, 0x0000000000000000). A dump was saved in: C:\Windows\MEMORY.DMP. Report Id: 091211-27003-01. _______________ The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly. _______________ The Microsoft Antimalware Service service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 15000 milliseconds: Restart the service. _______________ Microsoft Antimalware engine has been terminated due to an unexpected error. Failure Type: Crash Exception code: 0xc0000005 Resource: file:C:\Program Files (x86)\Common Files\ArcSoft\Connection Service\Bin\ACDaemon.exe _______________ Good lucky to your recaps. Last edited by jcmygod; 09-18-2011 at 05:08 PM.. Reason: Updated cap removal details. |
#26 |
thanks bad cap!! fixed a hp pavilion 8200n with mcp61pm-hm just the 1800uf were bad.. all good now!!
thanks |
#27 | |
City & State: Ca
My Country: USA
I'm a: Knowledge Seeker
Quote:
what type of replacement capacitor did you use to replace your old 1800uF 6.3V TK capacitors and where did you got your replacements. Thanks |
#28 |
Radioactive
City & State: tehas
My Country: US
Line Voltage: 120VAC 60Hz
as far as the bugchecks go, it would not matter, cause any kind of instability crash addresses can be caused by bad caps, all depends on how unstable the voltage is to ether the ram or in this case the cpu and whats running in windows to cause the crash
as far as the post right above me, you can usually get them here. here are some ULESR nichis that should work http://www.badcaps.net/store/product...roducts_id=145 these rubycons also should work http://www.badcaps.net/store/product...products_id=41 I kinda wish TC would stock pannys and sanyos, but yeah, that not going to happen any time soon |
#29 | |
Unknown
Quote:
just get the kit (http://www.badcaps.net/store/product...roducts_id=161) and replace the lot. |
#30 |
Unknown
He did actually try to get panny when Rubycon stopped selling the MBZ series, but panny flat out refuse to sell the FJ or FL series to anyone except for Manufacturers
#31 |
City & State: Kayseri
My Country: Türkiye
Line Voltage: 220vAC 50Hz
Hi friends. my name is Kenan. 1800uf 6.3V capacitors bulged my mcp61pm-hm motherboard and my computer has failed. I replaced the capacitors, but now will not turn on my computer. When I pressed the power button on the motherboard, CPU and other fans of energy comes from running but no display screen and the bios does not have a warning fans will always continue to work at the same speed. Contrary to turn off the computer power button to turn off the computer long pressure fans begins to turn quickly refreshed. I changed all the solders again renewed, and all the capacitors, but I could not find a solution. Please help.
#32 |
City & State: Romania
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Hi Kenan.... what I should do if I were you would be to check if the power supply of the computer is working properly.
The capacitors on the motherboard can die from the excess heat and from poor "workmanship" but they could also fail due to receiving poor quality power from the power supply (high ripple, high voltage etc) You should the very least open the case of the power supply (after removing the mains cable and waiting a couple of minutes for the energy to be leaked out from the capacitors inside). Inspect the insides and see if there's something bulging or in any way looking differently than other capacitors. If you have access to a multimeter, close the lid on the psu and connect it to mains, start it up and check the voltages it outputs when it's not connected to a pc (you have to short two pins in the main 20-24 pin connector for the power supply to start) The green cable/pin needs to be shorted with a wire to ground (one of the black cables) for the power supply to start and output on the rest of the pins. Note the voltages down and repeat the procedure measuring the voltages when you start the computer (connect mb and everything to the psu). See if the voltages are still within acceptable limits (5v and 12v +/- 5%) |
#33 |
My Country: Türkiye
mariushm hello. Thank you for the reply. I tested a PSU is working properly. One of my friends have tested it and there is no problem mcp61ph-hm motherboard does not appear. Bios chip bios motherboard my friend I wanna put my anakartıma also did not alert.
#34 |
Getting there
did you ensure the polarity wss correct when reinstalling your new caps?
#35 |
Unknown
Also, what caps did you use to replace them? If you didn't use super low ESR caps, then it will not work.
#36 |
More Knowledge
City & State: The Frozen Tundra of WI
My Country: USA
I know that it can be bad form to dredge up an old thread, but this was the latest on this motherboard that I could find and I have a couple of questions.
First, a friends computer with this board is having problems getting past the post stage and will neither start Windows nor enter the Bios. All 9 of the 1800uF 6.3V caps are bulging but not leaking. Does this behavior sound like it could be caused by the bulging caps? Next, if that does appear to be a strong candidate should I go with Nichicon HN, HZ, or would you guys recommend something else? All of the other caps look to be in good shape and this person really doesn't have much money to spare on this (met here at the local Food Pantry where I volunteer) so I'm trying to do this as economically as possible. the $13 difference between the complete kit and just the 9 may not seem like much, but to some folks it can be the difference in eating one small meal a day or 3 reasonably sized ones. Any advice would be welcome here. |
#37 | |||
Unknown
Quote:
Quote:
See http://www.badcaps.net/store/product...roducts_id=161 for Revision 1 or http://www.badcaps.net/store/product...roducts_id=180 For revision 2 Quote:
#38 |
More Knowledge
My Country: USA
Thanks for that info c_hegge. I compared the caps listed in the kit for the Rev 1.0b board and ran into a slight problem. I can account for all of the 1800uF 16v, 1800uF 6.3v, and 1000uF 6.3v caps. I can only find two of the five of the 470hF 16v caps on the board. The board looks identical to the one you posted a pic of in post 12. One is next to the blue IDE connector and the other is between the two PCI-E slots (the one away from the speaker). Any idea where the other three are supposed to be located? Am I missing something here? I don't want to order the wrong set or miss something.
#39 |
Unknown
The one in post 12 is a stripped down version, with fewer DIMM slots, and no firewire. The missing caps are used on the fully featured version for firewire output filtering. So just use the rev 1.0b kit and keep the extras as spares.
#40 |
More Knowledge
My Country: USA
Okay, thanks. I'll order one of those shortly.
| Thread Tools | |
| Display Modes | |
