Rubycon fakes??? or just blown?
  • alendarc
    • Mar 2012
    Re: Rubycon fakes??? or just blown?
    Originally posted by mockingbird
    How fake cap sellers on eBay operate:
    There is a large network of "trinket" sellers on eBay. They sell anything from iPod silicon covers to LED gizmos.
    Usually they will [also] have a section dedicated to counterfeit and usually low-quality but good looking [fake capacitors]. They start to sell to unsuspecting individuals. When they start to receive enough negative feedback, they switch the entire capacitor section to another seller in their network. When the previous seller has built up sufficient positive feedback from selling their other trinkets, they will switch the capacitor inventory back.
    This way, they can stay ahead of the negative feedback that would otherwise ward off most people.
    An example:
    Seller is "goodbuy7888" from Hong Kong.
    You have to dig pretty far back in his feedback to find this.
    They're getting smarter and smarter and the fakes are getting better and better. I picked up a Panasonic FC from a relatively local electronics shop that is almost visually indistinguishable from the real thing. Avoid caps from eBay Hong Kong sellers.
    That seller "goodbuy7888" is back. Observe how every capacitor listing has exactly the same ripple spec:
    http://www.ebay.com/dsc/m.html?LH_Ti...sn=goodbuy7888
    An "another seller in their network" is "allpartspipe2008" also with that ripple spec repeated from one listing to the next:
    http://www.ebay.com/dsc/m.html?LH_Ti...lpartspipe2008
    Notice that the identical specifications format is also used by the good guy mentioned numerous times in these forums "PCMCS/egekecu" who is a Hong Kong seller too:
    http://stores.ebay.com/PC-MotherBoard-Capacitors-Store
    P.S. What is "Ctgy Temp"?
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Either the PCMCS dude is also a counterfeiter, or he simply uses the same eBay templates everybody else does
      • c_hegge
        • Sep 2009
        • 5219
        I think he just uses the same template. His caps are definitely Geunine.
        The guy I got the sacons from also uses a similar table. Compare http://www.ebay.com.au/itm/10-xNIPPO...item45fabdd056 (but, obviously, don't buy them, unless you want to use them as fireworks)
        • cmlewis89
          LG 47LB5DF blown power supply board
          by cmlewis89
          Hi folks,
          I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
          09-03-2024, 07:50 PM
        • drscoot
          HP X360 convertible battery blown fuse error, not charging
          by drscoot
          HP Modelnumber: 14-dh0061nb​
          This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
          The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
          I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
          And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
          All these 3 batteries are charging...
          12-15-2023, 05:54 AM
        • swerg
          Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
          by swerg
          Hey everyone,
          I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
          I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
          I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
          06-06-2024, 03:39 PM
        • ohren
          What problems could this blown cap cause in a Marantz SR5400?
          by ohren
          I'm looking at a vented C513 in a Marantz SR5400 (photo included), in the FR section on page 24 in the service manual (https://audiocircuit.dk/downloads/ma...400-avr-sm.pdf).
          R533 right below it in the photo is charred, but measures the correct value.
          1. I'm not familiar with amplifier circuits (at all — don't know the difference between classes, etc.) so I was wondering what problems would manifest from a supposedly non-operational C513? I didn't hear anything odd when testing the output channel with a speaker. Is there a simple test that can be done...
          10-21-2025, 09:02 AM
        • MrzPdlch
          Blown fuses on Gigabyte GTX 980TI 6GB
          by MrzPdlch
          Hey everyone,
          I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
          Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
          Find some pictures of the actual GPU together with a picture of how it should look like.
          I also wonder whther it might be a problem that there...
          03-10-2024, 04:14 PM
