Capacitor nominal value
  • Thermaltake
    Brain badcap
    • Aug 2015
    • 339
    • D12
    Hi, happy new year!
    I am buying capacitors locally and from ebay. Some capacitors locally and on ebay are sometimes rated more than their value, I know there is plus minus 20% offset, but is it true that if capacitor is lower than rated let's say cap. is rate as 3300uF, and 10 of capacitors that I bought are around 3000uF, is that consider an old capacitors that were stored for longer period even if they weren't solder before ? Would that kind of capacitor last same as the one that should be rated as their original value or a bit more. And would they perform same ?
    I am about to recap one PSU with low esr caps, but not sure if I reorder some new with a bit closer to original value or do you think the ones that were rated 3000uF are still ok to solder and would perform same ?
  • joetristan
    Tantalum capacitor burning out
    by joetristan
    I’m using a 10 µF, 20 V tantalum capacitor as a decoupling capacitor across a 5 V supply. When I power the circuit, the capacitor burns out.
    At first, I assumed the tantalum capacitor was defective and replaced it, but the new one burned out as well when the circuit was powered.
    I then replaced the tantalum capacitor with a 10 µF, 63 V electrolytic capacitor. This time, the capacitor did not fail after powering the circuit.
    I do not understand why the tantalum capacitor burns up?
    02-11-2026, 03:43 AM
  • jkucukov
    ASUS Zenbook 13 Laptop UX333FN Need Help with SMD Capacitor Identification
    by jkucukov
    I have a ASUS Zenbook 13 UX333FN motherboard that I need to replace a SMD capacitor. This SMD capacitor is located on the back side of the motherboard and is really small (C0201), however I need to find the specs of the capacitor (Voltage rating and Capacitance).
    I was fortunate to find Boardview file for however all I was able to get from the file is the Capacitor reference designator (C6353), here is the information:
    How would I be able to get Voltage rating and Capacitance of the SMD Capacitor?
    Thanks,...
    08-11-2026, 09:00 AM
  • Prolog
    by Prolog
    12-01-2024, 08:27 PM
  • woodboy971
    Need help – Identifying missing capacitor (HP CM 6050A2892401 MB A01)
    by woodboy971
    I am a beginner in electronic board repair and I am looking for help with an HP motherboard: CM 6050A2892401 MB A01.
    Initially, the laptop would not power on. After troubleshooting and taking measurements, I found that a capacitor was shorted, which was preventing the system from starting. I removed this capacitor.
    After removing it, the PC now powers on for a few seconds and then shuts down. I believe this behavior is related to the missing capacitor, which is no longer performing its role in the circuit.
    My issue is that I cannot identify...
    12-27-2025, 10:31 PM
  • Quadro1000
    MXM Graphic card Nvidia Quadro K1000m /K2000M schematic or value of capacitor C55 capacitance and voltage from laptop HP8570w
    by Quadro1000
    I had a MXM graphic card type Nvidia K1000m from laptop HP8570w which had a broken capacitor.
    The ceramic capacitor seems was broken and makes a short circiut. The laptop goes off because of the short-circuit. But it seems currently that only the capacitor C55 was broken on the graphcic card.
    Because after I have desoldered it, the laptop runs with the card. But currently without this capacitor.
    So to have full functionality and no instabilities I want to replace it with a new one.
    So I need to know the value and voltage of C55 to replace...
    12-16-2025, 11:17 AM
