I’m using a 10 µF, 20 V tantalum capacitor as a decoupling capacitor across a 5 V supply. When I power the circuit, the capacitor burns out.
At first, I assumed the tantalum capacitor was defective and replaced it, but the new one burned out as well when the circuit was powered.
I then replaced the tantalum capacitor with a 10 µF, 63 V electrolytic capacitor. This time, the capacitor did not fail after powering the circuit.
I do not understand why the tantalum capacitor burns up?
Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
Capacitor nominal value
by joetristan
Channel: General Capacitor Questions & Issues
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
I hope these photos make it clear which component I am referring to:
(yes, the soldering is a bit botched from removing the blown one, I know)
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... -
by woodboy971Hello everyone,
I am a beginner in electronic board repair and I am looking for help with an HP motherboard: CM 6050A2892401 MB A01.
Initially, the laptop would not power on. After troubleshooting and taking measurements, I found that a capacitor was shorted, which was preventing the system from starting. I removed this capacitor.
After removing it, the PC now powers on for a few seconds and then shuts down. I believe this behavior is related to the missing capacitor, which is no longer performing its role in the circuit.
My issue is that I cannot identify...3 Photos-
by Quadro1000Hi,
I had a MXM graphic card type Nvidia K1000m from laptop HP8570w which had a broken capacitor.
The ceramic capacitor seems was broken and makes a short circiut. The laptop goes off because of the short-circuit. But it seems currently that only the capacitor C55 was broken on the graphcic card.
Because after I have desoldered it, the laptop runs with the card. But currently without this capacitor.
So to have full functionality and no instabilities I want to replace it with a new one.
So I need to know the value and voltage of C55 to replace...-
Channel: Schematics and Boardviews
by devsignerHi
While messing around with my MacBook Pro, I stupidly pinged off a very small surface mounted component that I’m now trying to identify.
resistance tests show a rising resistance value, indicating a capacitor.
The laptop boots up and runs, however I'm choosing not to use it until I get it fixed.
i can’t see any markings on the capacitor at 10x magnification using a professional jewler's loop.
It seems like there's some damage to the capacitor - one side doesn't have "shiny bits" - can you tell I don't do this for a living!...5 Photos - Loading...
