Vendor-Series Equivalents
  • PeteS in CA
    • Aug 2005
    • 3589
    • USA, Unsure of Planet
    • Reading, Education, History, Christianity
    This is organized vertically, higher Z to lower Z ratings (based on 50V, 16mm x 25mm parts for the 5K-10K hours series, and 2200uF, 10V, 10mm x 25mm part for the 2K hours series) and alphabetically L-R. The rated life is noted for each group.
    Nichicon PJ // UCC LXV
    Nichicon PW // Panasonic FC // Rubycon YXF // UCC LXZ (8k Hrs. except FC 5K Hrs.)
    Rubycon YXG (6K Hrs.)
    Nichicon HE // Rubycon YXH // UCC KY (10K Hrs.)
    Nichicon HD // Rubycon ZL // UCC KZE (5K Hrs.)
    Rubycon ZLH // UCC KZM (10K Hrs.)
    Panasonic FM (7K Hrs.)
    Nichicon HM // Sanyo WG // UCC KZJ (2K Hrs.)
    Nichicon HN // Rubycon MCZ // UCC KZG (2K Hrs.)
    Nichicon HZ (2K Hrs.)
    PeteS in CA
  • DrewPhillips
    Capacitor Diarrhea - Nichicon PL Series
    by DrewPhillips
    Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
    The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
    03-02-2025, 10:18 PM
  • Andre Gilbert
    by Andre Gilbert
    11-20-2024, 08:52 PM
  • Yanleb
    Need part number for Q051(aka Q16051) from the Panasonic TNPA4659 SS board
    by Yanleb
    This is very frustrating. Someone removed Q051 from a Panasonic TNPA4659 SS board from a TH-42PX80UA without writing on the board the actual part number.
    As usual, the Panasonic service manual only lists the Panasonic part number B1JADN000003. There's no other component with the same B1JADN000003 number on the board, so I cannot figure it out.
    Do you have one on hand that you can read the actual part number from it? This is not the TNPA4659AB with the AB suffix for the 37in TV, this is the TNPA4659 without a suffix for the 42in TV.
    05-01-2026, 12:22 AM
  • Boardview Bios and Schematic Bot
    Panasonic Toughbook CF-Y7 Laptop Schematic
    by Boardview Bios and Schematic Bot
    Panasonic Toughbook CF-Y7 Laptop Schematic...
    03-13-2026, 06:05 AM
    Panasonic Toughbook CF-M34 Laptop Schematic
    Panasonic Toughbook CF-M34 Laptop Schematic...
    03-13-2026, 06:04 AM
