Hello everyone. Glad to join. See you around!
New Members - please post your introductions here
This is a sticky topic.
Ciao, mi chiamo Rosario, sono un tecnico in pensione, vivo in Italia e mi diverto ancora a riparare diversi tipi di schede elettroniche. Sono membro del forum da diversi anni e leggo sempre con interesse sia i problemi tecnici che le soluzioni proposteComment
Hi everyone!
I'm Holger from Switzerland, 62 years old. Skilled electronics and PCB Layouter, I'm "out of business" for over 10 years now. I'm here to find some help for complicate problems, especially in the PCB repair area. Let's have fun!
Greetings HolgerComment
Hi! Hobbyist here, I'm actually a baker, but I kinda grew up between machines and always had an interest in anything technical. I never really gone down to 'pcb level' though.
I have a broken laptop, something with the charging circuit. The way some things went down I can kinda localize the problem. The case is broken and it was pretty cheap so yeah... I'd like to try some stuff out and perhaps I can get a little more insight in those abstract green boards :pComment
Ola pessoal, sou do Brasil
Com uma pesquisa na rede descobri o badcaps,fico muito feliz em participar desse fórum , obrigado a todos os integrantes e em especial aos adminsComment
Hello I'm JC. New to board repair, trying to learn and grow. also if I can Help you, it would be awesome, Have a good day guys!!
ThanksComment
Hallo from Germany
I am going to fix PIONEER VSX 859 Receivers - many infos on my museum page
http://www.hifimuseum.de/der-vsx-859-rds-01.html
need to find the "factory reset" of the Pioneer VSX 859 RDS, to fix "POWER DOWN" Error
greetings from Germany
by fredyjbiplease help friends thinkpad T470 board CT470 series NM-A931 error post "bottom cover tamper detection error"
I've already
flashed the bios clean me and updated from the Lenovo site, then removed the switch and immediately jumped the S3 from pins 1 to 4, 2 to 3 but the problem remained the same, thank you1 Photo -
by fredyjbiplease help friends, I have 3 T490 units with the same case, the USB type C is completely dead, showing 20v 0 amp, loss of voltage VINT20_IN resistance to ground is fine, thank you
I think the problem is that I lost the voltage at PQ0008 pon 1 -PWRSHUTDOWN which should have been high which was picked up by R9512 VCC3SW, thank you very much for your help
PF0002 20v
PQ0005
pin 5 20v
pin 1.2.3 19.8v
pin 4 19.8
resistance
source & drain 2,4 m
source & gate 100k
PQ0006
pin 1.2.3 19.8v
pin 4 19.8v... -
by fredyjbiplease help friends x1 yoga 7th no display beep melody thank you...
Channel: BIOS Requests ONLY!
by fredyjbiplease help friends clean me bios x1 yoga 7th no display melody beep, thank you
by fredyjbiPlease help friends, thinkpad t480 nm-b501 is dead, help me fix it, thank you
usb meter 20v 0.00 amp, after I took the VSYS measurement the drop was only `9.2v which should have been 10.2v I measured from a normal matherboard machine, the VSYS path resistance to ground diode mode is 1900 thank you
LINK to Schematic -> https://www.badcaps.net/forum/troubl...b501-schematic - Loading...
