Westinghouse 52" LCD Ticking Noise
  • kingrock
    • Aug 2010
    I have a 2 year old Westinghouse 52" LCD. The display and sound work just fine.
    The problem is that when I power it off, there is a constant ticking/clicking sound coming from inside the back panel. It isn't very loud, but in a silent room, you can hear it. It's almost like an electric arcing noise, ticking/clicking/squealing. It is definitely not coming from the speakers. It is definitely not a heating/cooling issue. When I pull the plug out of the power strip, the ticking/clicking stops. When I plug it back in, it resumes. When I power the TV on, the ticking/clicking turns to a high frequency noise for a brief second and then there is a loud single click and the sound disappears while the TV is on. When I use the "fast startup" option on the TV (I think it keeps the TV powered on with the display in standby, rather than a full power-off), the noise usually isn't there.
    I want to know what may be causing this noise and, more importantly, if it is okay to keep operating it like this or if it is something that could further damage the TV down the road.
    Thanks,
    Steve
  • eliemgh
    lenovo t14 i7 10 gen : I press the power button and there is a loud fan noise
    by eliemgh
    lenovo t14 i7 10 gen : I press the power button and there is a loud fan noise for about 3 seconds and power light is on. Nothing on display screen. i have removed the battery and bios battery still the same. i have put yesterday on update and charger ,i have leave and back and see this problem. Any One Can help Me ?
    09-27-2024, 02:40 AM
  • ntoskrnl
    [FIXED] XFX Core Edition Pro 450W ticking noise
    by ntoskrnl
    My XFX Core Edition Pro 450W power supply started making a weird ticking noise some time ago. Eventually, I figured out what the issue was, and managed to fix it. I purchased this unit back in 2012, so it's an old model, but I'm still posting this in case someone finds it helpful or interesting.
    THE PROBLEM
    The power supply started making an irregular ticking noise when running, but would otherwise work perfectly fine. The issue would sometimes come and go. A Google search for "xfx core ticking" found multiple other people reporting the same issue, so I assume this...
    04-19-2022, 10:36 AM
  • NConstantinou
    HP Z840 workstation power supply clicking noise
    by NConstantinou
    No power
    i have the above ps which i change the TOP258eg ic.
    Now i have power but is clicking and voltages are flutuating. I change all capacitors, i test all mosfets and all are ok.
    i am wondering what is the value of R901! I am getting 0.5Ohms. Is that correct!
    the colours look like R,R,W or silver,G Bl.
    Thanks...
    12-25-2024, 02:24 AM
  • justice171
    Lenovo E15 Gen 2 Keeps Beeping Loud Noise
    by justice171
    Hello Badcaps Members,
    I'm experiencing an issue with my Lenovo ThinkPad E15 Gen 2, and I'm hoping someone here might have some insight. The laptop charges to full capacity, but as soon as I power it up, I get a loud sound, and there's no POST.
    I disconnected the battery and connected a USB meter, which shows 20V 0.23A when the sound occurs. I've already tried changing the screen, but it didn't resolve the issue.
    When I use Lenovo PC Diagnostics App I get results as 01000
    Here are the details:
    • Model: Lenovo ThinkPad E15 Gen 2
    • Board Numbe
    10-01-2024, 09:19 PM
  • tony359
    by tony359
    11-28-2023, 05:18 AM
