SAMSUNG UE55MU6442 - no standby
  • krzysiek-gda
    • Oct 2022
    • 4
    • Polska
    Hi i have Samsung UE55MU6442
    the tv will not turn on, there is no standby light,
    Main board BN41-02568B (BN94-11958M)
    Screen CY-KM055HGAV2H
    when i remove the psu cable to main board i get backlight
    attached my dump file from 25Q40
    Can someone send me the right file please?
  • lotas
    • Jan 2016
    • 4803
    • Russia
    Re: SAMSUNG UE55MU6442 - no standby
    Try.
    • Diah
      • Feb 2013
      • 6496
      i don't think this is spi issue. if there no STB light... mean to me 3.3V rail are dead. but i hope it worked for him
      • lotas
        • Jan 2016
        • 4803
        • Russia
        If the firmware 25Q40 (standby) flies, then the LED will not light up in this chassis either.
        • krzysiek-gda
          • Oct 2022
          • 4
          • Polska
          Originally posted by lotas
          Try.
          lotas! I love you!
          Works from first try
          • Diah
            • Feb 2013
            • 6496
            but the 3.3v rail come from dc to dc converter on MB and its feed also the spi vcc .. so need to know if spi vcc can located on it or not.. this info only at the OP head lol good work lotas.. i love it
            • Diah
              • Feb 2013
              • 6496
              yes i can see hex 0h to 1000h are empty and some empty sector later are computed... funny.. but good job lotas
              • lotas
                • Jan 2016
                • 4803
                • Russia
                Firmware 25Q40 is responsible for the standby mode and the power on it is 3.3v constantly.
                • Diah
                  • Feb 2013
                  • 6496
                  but at same time this 3.3v will be available at IR and front STB led... i cant imagine stb led will be from start off at time he plug it in wall.. at least blink for few ms.
                  • Citymin
                    by Citymin
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
                    09-07-2024, 05:50 AM
                  • GeckoGreen
                    Samsung service bulletin: need firmware file for PN63C550 TV
                    by GeckoGreen
                    I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
                    You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
                    The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
                    Will you please help me get the [2D63]LOGIC.bin file for my TV?
                    05-17-2025, 02:47 PM
                  • tvguy12012012120
                    by tvguy12012012120
                    02-07-2025, 05:13 PM
                  • ChristianBr01
                    LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                    by ChristianBr01
                    I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                    The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                    What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                    04-23-2025, 01:48 AM
