Epson EB-S03 Hdmi Problem
  • falcontech
    • Oct 2013
    • 470
    • italy
    Good afternoon
    I have the hdmi input of an Epson EB-S03 projector that does not work, in the attached photos there is the card which is a H550M_R1, I read somewhere that replacing the eprom circled in red solves the problem and among others things does not need software, just replace it, the eprom is a tssop 24c02, has anyone ever dealt with this type of repair? Thank you
  • falcontech
    • Oct 2013
    • 470
    • italy
    Re: Epson EB-S03 Hdmi Problem
    this is the eeprom
    • Diah
      • Feb 2013
      • 6365
      did you tried VGA port??
      • falcontech
        • Oct 2013
        • 470
        • italy
        The vga working
        • Diah
          • Feb 2013
          • 6365
          then you have weak HDMI signal.
          • falcontech
            • Oct 2013
            • 470
            • italy
            And so?
            • Diah
              • Feb 2013
              • 6365
              test with feeding hdmi port from signal generator
              • s_henya
                EPSON EB-X18 No HDMI input
                by s_henya
                Not my usual equipment repair, Projector works great but no HDMI input.
                motherboard: H550MA_R1
                HDMI socket was a bit chipped on the side, but no critical damage, i replaced it anyways but still no signal.
                Im assuming other damage in the mainboard.
                Can anyone give me some pointers on where to begin?...
                06-13-2025, 09:06 AM
              • theone111
                by theone111
                3. Problem: TV shuts down
                07-22-2024, 10:36 AM
              • redwire
                Onkyo TX-SR607 HDMI problem showing a black screen intermittently
                by redwire
                Onkyo TX-SR607 HDMI problem showing a black screen intermittently, audio was OK.
                It would usually cut out a few minutes after power on, for maybe 1 minute then work OK, then cut out and go to black again. Or fade out to sparkles and noisy video.
                Well known is these boards need recapping and there is a strange mix of parts on both sides of the board.
                The bottom of the board has 100uF 4V (5.3*5.3mm, qty 5) and 220uF 4V (6.6*6.6mm, qty 5).
                Per the service bulletin, an issue is the Toshiba LDO's want low ESR for stability so I went with 100uF 6.3V polymer...
                11-16-2023, 08:56 PM
              • Zeonalbasta
                Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                by Zeonalbasta
                i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                09-13-2024, 01:17 PM
              • shopy
                Lg55 led tv hdmi input problem need help
                by shopy
                i have a strange problem with my LG 55 led tv HDMI INPUTS.
                when i connect the cable tv HDMI to the HDMI input of the lg led tv .the tv says NO SIGNAL .but if i connect to the same inputs a china tv box all is working fine. all the HDMI inputs are the same. non of them work with cable tv but work well with the china tv box.
                this happens only on this specific tv another tv i have work fins with the cable tv and with the china tv box.
                i cant figure way it happens in this tv only.
                thanks, to the helpers?
                12-05-2020, 11:47 AM
