Sony KDL-46R450A No Power, No red LED status
  • joeward
    • Jan 2011
    • 9
    Hello all,
    I've been trying to solve this issue and maybe someone can make me check in the right direction.
    Sony KDL-46R450A no status red LED, no Green LED, no power. TV wouldn't turn on 6 hours after beeing turned off last week
    PSU 1-888-122-12 (GL5 APS-350)
    Some kind of relay click is present on PSU. repeats every 4-5 seconds.Power button pressed makes no difference.
    Cable to mainboard voltages measured at different pins
    Ground taken from Ground Screw on secondary in all tests (except for Primary cap)
    (PSU AS IS still hooked up from inside TV.)
    1 GND
    2 VCC_3.3_STBY = jumps from 0.6V to 1.14V after each "relay" click
    3 GND
    4 POWER_ON/OFF = 0V
    5 VCC_12V = 0V
    6 ACC_OFF_DET = 0V
    7 VCC_12V = 0V
    8 BLKT_EN = 0V
    9 AUDIO_12V = 0V
    10 BL_CNTL = 0V
    11 AUDIO_12V = 0V
    12 BKL_ERR = 0V
    13 VCC_12V = 0V
    14 GND
    15 VCC_12V = 0V
    16 GND
    Main CAP from Primary (450V 82uF) measured straight at pins voltage jumps from 240V to 260V at each relay click
    If I disconnect cable from PSU to Mainboard (Differences from previous results)
    no relay clicks
    2 VCC_3.3_STBY = 3.3V
    6 ACC_OFF_DET= 3.3V
    Main CAP from Primary = 164V
    Took PSU out of TV Checked Main Fuse (not open) and different components.
    no relay clicks
    Put a 1k Ohm between VCC_3.3_STBY and POWER_ON/OFF:
    2 = 3.3V
    4 = 3.3V
    5 = 12V
    6 = 3.3V
    7, 9, 11, 13, 15 = 12V
    8, 10, 12 = 0.02V
    Main CAP from Primary = 399V
    I ve checked many fuse resistors none are open, no indication of burned components
    Checked mosfets none seem shorted
    Any help on anything I should look for next ? Could it be a mainboard issue ? I just find it weird with the no power at all.
    Thank you so much
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Sony KDL-46R450A No Power, No red LED status
    I would say you have a mainboard problem.
      • 12276
      • U.S.
      go ahead and add a 1k resistor from bl_cntl to standby along with the other jumper and see if the backlights come on, leaving the cable from powerboard to mainboard unhooked of course.
      • joeward
        • Jan 2011
        • 9
        Thank you for the reply
        I just tried adding 1k ohm from standby to bl_cntl keeping the other one there as well and no backlight came on.
        Cable from powerboard to mainboard disconnected, just LED cable connected to powerboard (CN6801)
          • 12276
          • U.S.
          ok, I don't know if you also need blkt_en jumped to standby also or not, I can not say for sure. I think it means backlight enable but not positive.
          • joeward
            • Jan 2011
            • 9
            I just tried adding another 1k ohm to blkt_en and this time yes, I do have backlights on. Does this confirm a faulty mainboard ?
            thank you for all the help !
              • 12276
              • U.S.
              pretty sure it means your backlights and powerboard are ok, so could be mainboard or tcon or panel I suppose.
                • 12276
                • U.S.
                maybe try some isolation, maybe start with unhook ribbon cables from tcon to panel driver board, then see if the clicking stops, if not then unhook lvds cable from tcon or mainboard, see if clicking stops, there was no clicking with cable from powerboard to mainboard unhooked right? I always make all connect and un-connects with tv unplugged from power, to try to avoid any errant surges and such.
                • joeward
                  • Jan 2011
                  • 9
                  in any combination I do hear the clicks.
                  Last combination was everything unhooked from mainboard (Cable ribbons and cables) leaving only cable from powerboard to mainboard and sadly I still hear the clicks.
                  edit: sorry forgot to say: right, if cable from power board to mainboard is disconnected i don't hear the clicks
                    • 12276
                    • U.S.
                    ok, I'm thinking mainboard issue too.
                      • 12276
                      • U.S.
                      Dskall nailed it in only 1 post,
                      • joeward
                        • Jan 2011
                        • 9
                        He absolutely did nail it in one post !
                        Thank you to the both of you for the help and the double checking.
                        • joeward
                          • Jan 2011
                          • 9
                          Just as a follow up, I did replace the mainboard and TV is back and running.
                          thank you again for the help
                          • CoinCoin88
                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                            by CoinCoin88
                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                            09-15-2025, 03:36 AM
                          • Carlos#2003%
                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                            by Carlos#2003%
                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                            02-15-2024, 07:52 PM
                          • DynaxSC
                            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                            by DynaxSC
                            Hi
                            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                            08-04-2025, 12:20 PM
                          • dkneyle
                            Sony KDL-46HX850 Can't upgrade/update firmware
                            by dkneyle
                            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                            09-25-2024, 10:44 PM
                            Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                            This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-06-2024, 05:27 AM
