samsung un50nu7100f
  • Crabcakes
    • Jul 2022
    • 7
    samsung un50nu7100f
    Hey guys I was wondering what could be causing my Samsung 7 series tv flickering it's vertical.Sometimes it will be fine for an hour then start to flicker.
  • neilc6
    • Nov 2015
    • 1550
    Re: samsung un50nu7100f
    Line looks horizontal. Check the YouTube video in Update 2. https://techhometravel.com/repair-of...ge-horizontal-
    • Crabcakes
      • Jul 2022
      • 7
      My bad I meant horizontal I did the tape thin but when ever I unplugged a ribbon u would just get a black screen on both sides
        • 12276
        • U.S.
        sometimes you have to play with where you put the tape, as in how many pins to block.
          • 12276
          • U.S.
          it's not a firm rule that you need picture on one side for the tape cutoff method to work.
          • Crabcakes
            • Jul 2022
            • 7
            Ahh ok I tried doing 10 pins on each side of the ribbons with no luck can someone point me to what else I can try. The thing is after I open the tv it will be fine for like 30 minutes or so then starts again haha ��
            • neilc6
              • Nov 2015
              • 1550
              Tape cutoff much more difficult on tvs with no separate tcon. Only seen it successful on one youtube video.
                • 12276
                • U.S.
                if it goes good for 30 minutes, i don't think it's a shorted panel, taping isn't likely to work.
                • Crabcakes
                  • Jul 2022
                  • 7
                  What else could it be if tape does not fix the issue?
                    • 12276
                    • U.S.
                    is the line always there, even for the 30 minutes that it works like it should?
                      • 12276
                      • U.S.
                      for now unplug any devices like dvd player etc, so nothing else plugged in, make sure ribbon cables from driver board to mainboard are clean and fit well, can clean with isopropyl alcohol, some use a pencil eraser, not to vigorous they can be delicate, look the cables over closely make sure there's no damage and they are aligned correctly, see if the line is on the menu too, change source, see if line stays on the next screen, It could be driver board issue, check the little capacitors on the driver board for shorts or very low ohms, don't get them confused, they are usually designated with a little C for capacitor right beside them, another thing to try is turn the backlights way down and see if the tv stays on longer.
                      • Crabcakes
                        • Jul 2022
                        • 7
                        Ok thank you I will try that next
                        • jneupauer@sbcglobal.net
                          • Apr 2018
                          • 9
                          UN50NU7100F
                          when the tape does not work, check panel pc boards for hot chips
                          overheating diode pack removal fixed this one
                          Radio Doctors
                            09-07-2024, 05:50 AM
                          • mrsith
                            Samsung UE70TU7100 - flickering horizontal lines
                            by mrsith
                            Hello again good souls.
                            Got an UE70TU7100. The TV starts up just fine, but right hand side of the screen is horizontal striped a bit, and there are some flickering horizontal lines on the whole length of the screen. I've seen similar static horizontal lines sometimes, when applying the cut tape method and covering wrong number of pins.
                            I've cleaned every connector with ipa, tried cut tape method on main LVDS ribbon as well as small ribbons, connecting the panel boards at the bottom. Tried squeezing the bezel and playing around COFs, but no reaction at all. COFs and...
                            02-13-2023, 05:36 AM
                          • kotel studios
                            Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                            by kotel studios
                            Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                            In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                            08-06-2025, 02:07 AM
                            09-06-2024, 11:40 PM
